H&R OR EVOSPORT COILOVERS ?
anyone using h&r or evosport coilovers ? just wondering what the difference is to the kw's . do they ride the same or not ?
MBWorld Founder
ones too fast according to CHP!
We feel that there is no better option in the world and have proudly been H&R's number one Mercedes dealer for 8+ years!
brad
MBWorld Founder
Motons are a decent damper. We are a reseller and have them on some of the race cars. However, Sachs or Ohlins are the best. We run a lot of race cars and have the benefit of seeing and using all of the better bits, which allows us to see for ourself what is marketing and what is real. As to the best dampers, it is easy to find - ask the companies that make the shock dyno's. They see them all and know what is what.
None of this matters, as none of these companies will ever make anything for the benz. We can do custom sachs or ohlins or JRZ, but the cost is 8K ish as they are custom.
brad
brad
1 Post
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
brad
brad
Motons are the same as JRZ but slightly better. The Moton guys came from JRZ. Just an FYI. I raced on JRZs for 7 years and had them rebuilt every season. the Motons have lasted 2 years so far no issues with nitrogen leakage or anything. I am looking at the KW variant 3's. Has anyone installed them ? Are they too harsh for the roads ?
MBWorld Founder
As an FYI to add more clarity to your comment: JRZ had three partners (J, R and Z). One stayed, one went to found Moton and one went to found ProTrac. So yes, they were VERY similar. However, that has changed very much with the latest advancements that JRZ made.
We are not even a JRZ dealer, we are a Moton and Sachs one. However, I will not use Motons on my own cars any longer. They are just not up to the same level of other dampers that cost the same amount.
And when you rebuild your Motons, don't ask for anything special, because you CANNOT. There are no adjustments you can make to the valving. You cannot use digressive or progressive dampening, or different piston profiles. You use what Moton gives you. That alone takes Moton out of the running to be a TOP level damper compared to Sachs or Ohlins.
They have great marketing though!
MBWorld Founder
I would have to do some research as I have not set-up any cup cars with JRZ's yet. I have done the 4-way Moton Motorsports as well as 3-way Moton Motorsports on BMW e46 chassis. And frankly, they never met my expectations.
I can find out the JRZ options for you if you would like, it is not a problem.
thanks
brad
thanks
brad
i just spent about 10 grand on the Motons so I am going to race them until the end of this season. I would like to hear what JRZ say has to comapre though
you can email me here thompsonmotorsports@gmail.com
thanks !
thanks !
