Remote Start?
C63 AMG(sold), 2009 CL550, 2010 S550 Majestic Black, 2010 ML550, 2006 C230, 2009 Venza
Remote Start?
Does anyone have any information on the progress on the remote start for the W204 from Mid-City Engineering? They were developing a remote start that fully integrates on the factory key but have not heard from them again around the forums. Anyone got any Intel on this ?
I beleive it's already out if you check their website. You can start it to warm up your car by pushing the button on your key, but in order to drive the car it seems you would still have to insert your key. It's not purely keyless but semi?
Personally I don't think it's that good because it's not fully keyless but it's good to get the car started up if you're in a cold area and wanna get the inside of the car hot enough.
Found the thread.
https://mbworld.org/forums/audio-ele...-smartkey.html
Hope this helps. I haven't followed up on it so I dunno how much. We can always call them to find out :/
2015 Jaguar F-Type R Coupe' '99' Audi A4 Avant Quattro 2.8 DD
Our starter has absolutely no wiring connections and no splicing into the vehicle. The entire starter is installed just behind the key cylinder module and uses factory connectors to allow it to plug into the factory wiring harness. At any time the starter system can be unplugged and removed and the vehicle would be *completely* stock configuration again. Thats plug-and-play.
MSRP on the starter is $999 for the C class. That includes everything you need to start the vehicle so there are no hidden extra costs.
Normally to get a remote starter installed the installing tech has a box with 25-40 wires which need to get spliced into the vehicle at various different points. Naturally this would sometimes cause warranty issues when the vehicle would be brought for service as the dealers like to blame any problems the vehicle has on aftermarket products that are installed int the vehicle.
Digging up an old thread here, but a dealer near me sent me an email saying they now have the SmartKey remote start system available. Anyone have this? I think they said $1495, not sure if that includes install but I would hope so. Thinking about getting this. Thoughts?
****, that's good news. I'm going to find out if they install at my dealer. I rather pay $500 more and do it through the dealer just in case.
2011 F458 Italia, 2012 C63 Coupe Black Series,2010 997.2 GT3 RS, 2011 Porsche Cayenne
2017 Mini Cooper S Clubman ALL4 - British Racing Green
My wife has a smartkey (the infiniti FX variant, not a push button, but a twist button similar to normal ignition, only you don't have to stick the key in it), and has an auto start, she just hits her lock button on the remote twice within 1 second of each other (yes that occasionally starts the car by accident when locking your car if you double tap).
The reason the car does not work until the actual ignition has been engaged, is so that they do not steal your car. In my wifes car, if she does not turn the actual ignition on, when she touches the brakes or gas pedal, the car shuts off.
and $1k+..... are they nuts....
If at any time while the vehicle is remote started, an unauthorized user attempts to enter the vehicle and drive it, the vehicle will shut down as soon as they attempt to engage the gear shift.
Yes the smartkey starter works with both keyless go and non-keyless go vehicles. When its installed on a Keyless go vehicle you retain all the KG features when remote started: so you can remote start the vehicle and still use the touch unlock feature to enter and the pushbutton instead of the key to start or take over... (or you can also just use the key like on a non KG vehicle.).
Viper Smartstart
Check out the Viper Smartstart on Youtube. You can control your car windows, start your car through your blackberry or iphone anywhere there is reception.
http://www.youtube.com/watch?v=zw3bCMcgv3A
What are your thoughts?
