Naive tire question 275 v 255
Is there more to this than meets they eye? At 5500 I need to dump my stocker rears and am trying to decide 255 or 275.
Thanks all!
X infinityJust switched to 265/35/18s for the rears last week. I get so much less tire spin now. Even pulling out of my neighborhood which is an uphill right turn I'd get some inside tire spin. Now it is much less. I'm hoping the rears last longer now and I like the added traction.
If the real speed is 60 mph then the odometer on the 265 shod car will read 59.3
Just add 1 mph to what the odometer says when driving the 265 car.
Though Savoy - you mention that traction is coming on which leads me to believe that you're slipping rather than sticking - if that is the case, the size is probably unrelated. HELP!
Follow your foot and heart, try and experiment, with tires they do not last long and after they wear out change to different type and or size and experiment to your own driving abilities and likes.
I have the 275x35x18's on the rear in the Toyo T1R's
I love them. They handle better and reduce the spin dramatically too.
I will be going to 245x40x18 Toyo T1R's in the front shortly to match the rear diameter.
Just my opinion!
Good luck!
Phil
Also stayed with 235's on the front.
