MHP Long Tubes 44rwhp over Kleemann Headers
As you can see the LT's include 3" pipe all the way back to the resonator.
Seriously, CONGRATS!! These things are awesome and do generate a tremendous amount of power! However, they are LOUD and if you are weak at heart then order the cats! They scare other drivers and large animals. Hey, thats the fun in having them.
Be safe and have fun racing!
Can't wait for cooler weather so we can see what they are worth in the 1/4. This Florida weather is NOT condusive to racing in the summer.
Wow amazing pickup on power! With that being said you stated the Kleemann pulled 432rwhp on better conditions, doesn't that mean that this new setup has more power to make once it gets cooler and air quality is better.
Do you plan to take it back to the strip?
The K2 package best pull was 432 in March and the car ran a 11.999 at 117mph with street tires on a semi decently prepped track. I have not seen anyone post a 440 K2 pull but it may have happened.
Keith and I use the same dyno and he pulled much lower numbers as well compared to winter climate. His gains were high also simply by replacing the shorties with the MHP LT's. Improvements over the OEM manifolds should be really profound!
Winter climate here in Florida may yield anything from 10-30 more rwhp but we won't know until later.
These pipes work great with the Kleemann tune if you already have it but Keith's numbers with the MHP tune are a bit higher. This is definitely a more expensive route, check the MHP site for current pricing just depends on what your goals are.
This is a true bolt on setup from block to resonator and accomplishes a rear cat delete in the process. Because it is sectional cats can be included just behind the collectors.
I will be selling the Kleemann setup at a reasonable price....more info will follow in the classifieds
On a side note, I wonder what happened to the A/Fs at 6600rpm, thats an odd spike. It may just be a one time fluke but it appears you may be able to pick up some more power if you lean out the mixture a bit, its getting down into the 11's which is pretty rich for an NA car. still, very impressive.
But back on topic, those gains are awesome hhughes! I didn't realize you were getting the long tubes, and I'm very happy to see they work well with your Kleeman tune! I've had mine sitting in the garage for nearly 2 months now, just been so busy/out of town all the time I havn't had a chance to get them installed. Next week for sure though
And then I'm hitting the track!Like others have mentioned...I can't wait to see you and Dads_C63 run side by side at the track, should be a very good race.
