C63 AMG (W204) 2008 - 2015
Did anyone try rolling their rear fenders?
Old Sep 1, 2009 | 11:06 AM
exdes's Avatar
2015 C300 4matic
Anyone try this?
how much additional clearance did you get?
I'm trying to see if there is way to fit lower offset wheels without having to cut the fenders..
Old Sep 1, 2009 | 11:14 AM
Sincity's Avatar
What offset and size of rear tires are you trying to put on? I slapped my old 9.5" et41 w/ 265/30/19 Brabus reps and it stuck out about 10-15mm too far out. I looked like a Dubber.
Old Sep 1, 2009 | 11:21 AM
exdes's Avatar
2015 C300 4matic
that bad? eh..
I'm looking at something with 9.5" and around +36mm..
Old Sep 1, 2009 | 11:22 AM
Sincity's Avatar
You will need to do what Josh did with his 63 and do custom bodywork to fit that. There really isn't a lot of metal there to fold back and fit larger wheels/tires.
Old Sep 1, 2009 | 11:25 AM
exdes's Avatar
2015 C300 4matic
is Josh his screen name?
Old Sep 1, 2009 | 11:27 AM
Sincity's Avatar
I forget his screen name. He is the one that has the Evosport tuned beast.
exdes's Avatar
2015 C300 4matic
Thanks!!
Old Sep 1, 2009 | 11:29 AM
iatacs19's Avatar
axe muderer with headlights
what rims are you looking at?
Old Sep 1, 2009 | 11:30 AM
Sincity's Avatar
Josh's SN is "C63 Guy."
Old Sep 1, 2009 | 11:31 AM
Sincity's Avatar
I was hoping that TSW would make a rear fitment of their 16 spoke wheel (like the AMG 16 spoke). They said not on their plans yet.
Old Sep 1, 2009 | 11:32 AM
exdes's Avatar
2015 C300 4matic
BBS LM.. lol
Old Sep 1, 2009 | 11:34 AM
Sincity's Avatar
LMs are too $$$$. I had 19" CHs on my MKV GTI. I try to convince myself that the 18s look right, but 19s are perfect.
Old Sep 1, 2009 | 11:42 AM
iatacs19's Avatar
Originally Posted by exdes
BBS LM.. lol
I want that too! with PS2s?
Old Sep 1, 2009 | 12:12 PM
sjhugh's Avatar
C63 AMG, BMW 135i
How difficult is it to roll the fenders on a C63?
Old Sep 1, 2009 | 12:16 PM
CynCarvin32's Avatar
Mercedes Benz
2 methods
1) heat gun and a rubber mallet.
2) fender rolling tool.
just take it easy. Cracked paint is pretty common but with MB paint that is still relatively fresh I have had good luck. Never cracked a thing. Older cars will crack just since the paint is so dry.
Old Sep 1, 2009 | 01:49 PM
Sincity's Avatar
There is less lip to fold on a w204 as compared to a w203 so it will be hard to fold back.
Old Sep 2, 2009 | 07:40 AM
sikvald's Avatar
C63 AMG
I have rolled my rear fenders, worked perfect. No rubbing after.
Old Sep 3, 2009 | 12:15 AM
C63newdude's Avatar
C63 AMG
What method did you used? do you have any pictures or any private link to show us your car? Thanks!
Old Sep 3, 2009 | 12:54 PM
sikvald's Avatar
C63 AMG
Heated the fender with a heat gun and used the fender rolling tool. Im running 10x on 285/25/20 with H&R springs without any problems now. You can see some pictures here:
https://mbworld.org/forums/c63-amg-w...installed.html
Old Sep 3, 2009 | 01:12 PM
exdes's Avatar
2015 C300 4matic
could you see what offset you have in the rear?
Thanks!!
Old Sep 3, 2009 | 01:22 PM
sikvald's Avatar
C63 AMG
Thanks!!
"Offsets are custom per car unless requested by the customer. We do not give offsets out because then other wheel companies can copy our fitments."
Let me know if you have any other quiestions.
Old Sep 3, 2009 | 10:14 PM
C63 Guy's Avatar
none
Yeah, we went full bore widebody with the beast. 1.75" flare on each side. I'm planning on running 315/25-19s on 11" HREs in back. I think I'm pretty close to 600hp at this point, so I want as much rubber on the ground as possible. The car is so, so very close to being done right now, and I'm waiting to post any more pics until it's finished.
Before we cut the fenders they were rolled, and it got a little more clearance, but I think a real widebody is the way to go to get the proper rubber on the ground.
Take care,
Josh
Old Sep 4, 2009 | 12:01 AM
moparrbust's Avatar
2005 Crossfire SRT-6
There are no welds on the 1/4 panel wheel openings like every other M-B. The 204's 1/4s are only seam sealed to the outer wheel house from the rocker cover to the rear bumper. If you really did take a heat gun and rolling tool to your 1/4 panel then you most likely separated the 1/4 from the wheelhouse. I bet if you take the wheel off and point a flashlight straight up you will see the two panels (now)separated.
Old Sep 4, 2009 | 08:38 AM
exdes's Avatar
2015 C300 4matic
Take care,
Josh
Do you remember how much clearance you got after rolling the fenders?
Anyways, so when are you going to show us your painted rear fenders?
Old Sep 4, 2009 | 11:31 AM
Sincity's Avatar
Glad you brought that up. Time to get the caulk gun out for those who did it.
