C63 AMG (W204) 2008 - 2015
Old 06-09-2015, 04:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY: interior trim replacement (long)
Old 08-28-2010, 11:34 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Awesome DIY! Looks Amazing!
Old 11-16-2010, 09:38 AM
MiamiAMG's Avatar
C63
Tag
Old 12-23-2010, 10:07 PM
tanga40's Avatar
Audi Q7, C63
Thanks so much for this post, ive been looking for this for ages
Old 05-07-2011, 01:08 PM
sheps's Avatar
C63
Likewise; thanks so much for such a detailed how-to.
It's certainly given me the confidence to get stuck in myself, there's nothing there that looks too tough.
I'll be honest, I'm not going true carbon, I'm doing a 3M Di Noc wrap on my std aluminium trims.
I'm looking forward to getting home tomorrow and ripping the car apart!
Looking forward to seeing mine done, as I have cream leather and I've not yet seen the cream leather with carbon trim.
Old 05-07-2011, 01:20 PM
sheps's Avatar
C63
Originally Posted by Samieee
Hey what's the "M" mode on the mode selector?
Manual.
Having the gearbox set in M-mode means gearchanges are controlled strictly by the paddles - no upchange, even when hitting the limiter.
The car will obviously make a downchange if the revs drop too low (where labouring or stalling would occur), but other than that, the driver is in strict control.
Old 05-07-2011, 01:44 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Did you pre-order the extra snaps and clips like the DIY mentioned? This is on my to-do list of mods after my wheels.
Old 02-07-2012, 08:31 PM
  #32
kHuNkHuNa's Avatar
White 2009 C300 Sport
best write up possible, THANK YOU
Old 06-21-2012, 11:49 AM
  #33
portchop002's Avatar
08 C300 4Matic
Has anyone vinyl wrapped the trim? I would love to see the differences between the real CF and a vinyl wrap.
Old 06-21-2012, 04:16 PM
  #34
rocketm's Avatar
C63, GLK350
I finally wrapped mine. It looks awesome. It is different compare to the real carbon you ordered from Mercedes. The wrap looks more like BMW carbon style. It only cost me less than $150 to buy myself a big roll of sheets and 5 hours of my time to wrap this thing.
Old 06-21-2012, 05:41 PM
  #35
08 C300 4Matic
Would you mind posting some pics
Old 06-22-2012, 01:31 AM
  #36
kHuNkHuNa's Avatar
could you please post pics and mention where you bought the sheets? i want to re do mine if this looks much nicer
Old 06-22-2012, 11:36 AM
  #37
Sincity's Avatar
^ There is a recent thread where a member wrapped his pieces using 3M Dinoc.
Old 08-11-2012, 09:24 PM
  #38
Amin Skaf's Avatar
2012 C204
Question - if I just wanted to replace the long aluminum trim piece on the door, behind the handle, would I still have to remove the entire panel to do so or would the tools pop it off?
Old 08-11-2012, 09:27 PM
  #39
kHuNkHuNa's Avatar
The door piece is screwed on to the door panel and to access those screws the door panel needs to come off
Old 08-12-2012, 04:56 PM
  #40
Sher Judge's Avatar
2017 991.2 Turbo PDK 2017 C63S Coupe Ceramic Brakes 2015 CLS63S AMG Full House
I stand to be corrected, but some company out there is manufacturing gloss finish carbon fibre vinyl, the scary part is how good it looks with the gloss over carbon depth.
Let us know if anyone has seen this?
Old 04-14-2013, 02:50 AM
  #41
louis1170's Avatar
E250 CGI
Remove interior trims on e-class coupe
Is there any similar post on how to remove interior trims for e class coupe w207 ??
Old 04-14-2013, 02:52 AM
  #42
louis1170's Avatar
E250 CGI
is there a similar post on how to remove interior trims for e class coupe w207??
Thank you in advance,
Louis
Old 04-14-2013, 02:54 AM
  #43
louis1170's Avatar
E250 CGI
Originally Posted by dockt
Door trim install (difficulty level = intermediate to advanced), major shout out to FUNKTION AUTO in Sterling, VA for letting me get back in their badass workspace, with their supercool tech, and follow the workflow. Also, to vic_viper whom I'm essentially copying. Sorry, no labels in the pics this time -- too much volume here.
Front door trim
Recommended extra parts on hand: rivets x 2 (PN: A000-991-79-40), orange paneling clips x ~10 (PN: A000-991-86-98)
Remove this thin molded plastic trim next to the lower portion of the window by the lock post. It's easiest to use a wedge tool to pry the trim's outside edge free from the door's metal edge (on outside of the car). Then pull out it's thicker base on the inside of the door.
This will reveal this funky rivet (PN: A0009917940). It is square, with an inner pin and an outside lock. Pry out the inner pin turn it 90 degrees and reinsert it into the outer lock part (there's a center stripe across the front of both parts that guides you somewhat. This unlocks the outer part and you can then remove the whole rivet. NOTE: I did not find that one is able to reuse this rivet once it's removed ie I wasn't able to pull out the inner pin out after doing the above procedure.
Now remove the two screws under the arm rest w/ a T30 torx driver. This is the simple little part that I didn't figure out on my own causing me to fail.
Also remove pull out the plastic tweeter cover and foam piece underneath.
You can now pull out the door panel starting from the bottom -- find it's edge where it meets the painted metal of the door. You have to use considerable force, but controlled -- if not, you will damage more of the orange paneling clips (PN: A000-991-86-98) than you want. As noted by vic_viper, you want to preserve and keep intact all of these orange clips including their thin foam washer as best as you can as they provide a seal from the elements and maintain pressure for the airbag sensors. Use the pic below to figure out the locations to pull out the panel ie near each orange clip. You can use a wedge tool but get in close to the clip locations to avoid damage to the clips and panel itself.
The top of the door panel is rubbery and is kind of hinged onto the metal part of the door; you just pry it up and out. As you remove the entire door panel, the lock post comes out from under it's hole.
Undo the purple and blue harnesses shown below. Also unlatch the anchor for the locking mechansm by pulling it up; then slide out it's cable more proximally from it's guide.
The door panel is now free; lay it upside down on a soft surface. Unscrew the 10mm hex bolts shown below for the long trim piece and seat control piece. The former will just come off after unscrewing.
For the seat control trim piece, remove the rubber sticker overlying it's white harness and undo both the white and blue harness. The trim piece along w/ the seat control mechanism (w/c is the back and butt control connected by some silver wire) can now be freed up from the door panel by undoing the trimpiece's tabs from the back of the panel -- a plastic frame will be left behind on the panel as shown below.
The seat control trimpiece has a bunch of little tabs around it that need to be released with a small, thin screwdriver head. Use your new trimpiece or the pic below as a guide. Do not break any of these tabs (my CF piece was missing a tab) as it allows the seat control to sit flush against the trimpiece -- just take your time, it's a little tedious.
Install your new long piece and seat control piece in opposite order from the above, replug the two seat control harnesses and recover the white one w/ the rubbery sticker.
Ensure that all orange panel clips with their foam washers are intact and anchored to the door panel's retaining posts (not into the metal door on the opposite end) -- replace with new clips if some are mangled. Reattach the purple and blue harnesses, the locking mechanism cable anchor and guide. Sort of hang the door panel onto the top of the metal door, putting the lock post through its hole. Line up the orange clips to their holes and bang close the panel with your hand. Work your way around the entire panel, bottom to top, banging at the location of the clips. You will know when each region fits "just right."
Use a new rivet (PN: A000-991-79-40) and replace it as noted above. Again note the marking "stripe" on top of the rivet to tell you it's locked position. Replace the plastic window trim.
If you made it this far, you are a better man than me actually -- but you're probably bleeding somewhere. Time 60-90 minutes for both doors, taking your time = GLORY!!
Rear door trim
Essentially same as front door but a) you do not have to remove any window trim b) there is no locking rivet in the panel to remove/replace. Make sure you unscrew the torx screws below the armrest again; then pry open the panel as above. Don't forget to deal w/ the lock mechanism, purple/blue harnesses, and lock post as above. The blue wire you see below is the locking mechanism from the driver's door.
Time = 30 min for both rear doors = GLORY!!
Old 04-04-2014, 01:52 PM
  #44
BK63amg's Avatar
'16 GTS Solar
Ressurecting this thread as I am going to use this to guide me in my CF trim replacement on my coupe tomorrow...wish me luck!
Old 04-05-2014, 07:16 AM
  #45
AMG893's Avatar
2010 C63 Estate
GL
Old 09-04-2014, 02:52 PM
  #46
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
For some reason I thought I saw that the door pieces were able to come off much simpler than having to take the whole panel off....
Old 09-04-2014, 03:20 PM
  #47
Kriston's Avatar
C63 AMG
Just in time for my OEM Carbon install
Great write up! I read it over before, but its good to have it close to the top of the forums!
Old 09-04-2014, 04:50 PM
  #48
olszowa12's Avatar
'08 C63 Estate
This thread has helped many many times. Best DIY ever!!!
Old 09-04-2014, 06:25 PM
  #49
chrisridebike8's Avatar
'10 C63
I used it too. I just sent my trim down to a guy in Texas to get redone in CF. The pics look amazing and I will do a thread once it's reinstalled. It should be here tomorrow. I can't wait!
Here's a preview
DIY: interior trim replacement (long)-46ace8c7-fa7d-40d7-93d8-5ab636cf017c_zps0qnb2sqd.jpg
Old 09-04-2014, 10:50 PM
  #50
Euro's Avatar
2008 CLK63 BS
Here's a preview
Who are you using in Texas? How expensive?
Thanks,
Mike
Quick Reply: DIY: interior trim replacement (long)
