Evosport | New Lightweight 2-Piece Front & Rear Rotors for C63
Weight savings will depend on whether you have the 1-piece or 2-piece OE front rotor now. If you have the 1-piece setup, then weight savings is 40-lbs unsprung weight. If you have the 2-piece setup, weight savings is 26-lbs unsprung weight. Total weight savings is on all four corners.
Here's the link again which explains this:
http://www.evosport.com/product/prod...VO.BRK.M04.R01
Hope this helps!
Hope this helps!
Hope this helps!
Evosport 2-Piece Rotor Installed on SL63 AMG (Note: Right-Side Rotor Shown):
That rotor was never installed on the car. Just used for the photo and at the time I didn't have access to the other rotor.
Curious Minds would like to know...
Simon, How far out are you on shipping a full front and rear set if I were to order within the next week?
For a full set, we're about 2-3 weeks out on new orders right now. We should be down to a few days soon as we're ramping on inventory, but these rotors have been selling very well.
1. Remove rear wheel (duh, took me a while as the Einstein where I had the service B performed air hammered them on
) - 17mm Socket2. Disconnect the stabilizer bar where the vertical member meets the cross member (you might not have to, but sure makes getting a socket on the top caliper bolt easier - 16mm Socket
3. Remove the caliper (2 bolts on inside of the caliper). Mine were tight as hell. I just swung it out of the way and rested it on the black plastic jack carrier that comes out of the trunk. - 18mm Socket
4. Remove the guide screw - Torx 30
5. Pull off the rotor - Rubber hammer
Reverse procedures.
Note: I used a jack (with a cardboard cushion) to jack up the bottom of the new rotor when reattaching the stabilizer bar (step 4).
I'll confirm all the Sockets tonight. Took me 1:15 hour on the first side and 30min on the other (once I knew what I was doing and had found all the appropriate tools. This time contemplates all the sweat equity of removing the lug nuts that were WAY too tight. Could have chopped at least 15min off at least.
