question about offsets...
2009 C63, 2000 Nissan Maxima
If I remember correctly the forgestar rear wheels are 19X10 with a +45 offset, versus 54mm for stock.
Compared to stock: with the offset and extra width, you're looking at wheels sticking out 21.5mm or 0.86" more than the stock wheels. It's not that huge but it will not allow you to drop the car much. The reason the offset is higher is to leave some room for the wider wheels on the inside.
so i think thats what ill probably go with
thank you for the input!
C63, Grigio Medio E46 M3
Quick question for the offset gurus. I have a set of 20" Radenergies off my E55 sitting in my garage. they are 20x9 ET34, and 20x10 ET34. Is there anyway these would work on the C?
You'll certainly rub for sure in the back..you're talking an extra 33mm pushed out toward the fender, and more if you go +1 on the tire
http://www.1010tires.com/WheelOffsetCalculator.asp
