C63 AMG (W204) 2008 - 2015
tire camber
Old Mar 18, 2010 | 09:37 PM
dmyrick's Avatar
C63
tire camber
My tire service manager told me my tires (rears} would last a lot longer if i had about 1/2 of the negative camber taken our at the dealer. what do up guys think?
Old Mar 18, 2010 | 11:02 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
Wow ... a service manager said that!! You car dosent have adjustable camber..
Old Mar 18, 2010 | 11:05 PM
hcetzneb's Avatar
Even if it did going more pos on the camber would help if you were wearing the inside edges on the tires.. and we all no c63 dont have that problem they wear very even on the rears... and with a heavy foot they wear FAST. Also if you pulled the camber in that much it would handle terriable in the rear
Old Mar 18, 2010 | 11:35 PM
BerBer63's Avatar
2009 C63
Anyone know how to adjust front camber or if it's possible?
Old Mar 19, 2010 | 01:01 AM
HIRO63's Avatar
c63
KW Clubsports coilover you can change the front camber. Im not sure with rear. Im planning to get this soon.
Old Mar 19, 2010 | 01:21 AM
Jae Duk's Avatar
'09 C63
Actually, for me my insides wear out faster...but it's not that noticible or that much of a different for me to go out and camber.
Old Mar 19, 2010 | 10:54 AM
dmyrick's Avatar
C63
Thanks for all the info
Old Mar 19, 2010 | 10:58 AM
NickZag's Avatar
no more AMG
Stock height or is your car lowered?
Old Mar 19, 2010 | 11:32 AM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
I just had a 4 wheel alignment done at my dealer and they pushed the Camber on all 4 corners to -1.9 (P30) using a different Camber Bolt. I may have the part # for the new bolts in my garage. will check when I get home later
Old Mar 19, 2010 | 12:31 PM
Jae Duk's Avatar
'09 C63
stock
Old Mar 19, 2010 | 06:29 PM
BerBer63's Avatar
2009 C63
That would be good to have Barry. Weird that the bolts didn't come stock because you can only adjust Toe if im not mistaken.
Old Mar 19, 2010 | 06:43 PM
Part # on the bag the new camber bolts came in is A 018 990 00 01. Set of 4 (Don't order til I confirm the #'s)
Sorry. the #'s above are for Calliper Bolts. The Correct Camber Bolt Part # is 000-333-09-71. (Single bolt) Set of 2 needed. $59.30 for the set here in Toronto
Last edited by NORTH 44 C63; Mar 19, 2010 at 10:24 PM. Reason: Incorrect Part # Supplied
Old Mar 19, 2010 | 06:50 PM
NickZag's Avatar
no more AMG
North_44_55, Thanks for always giving us those part #'s on your replies. They've helped me a lot
Old Mar 19, 2010 | 09:53 PM
No problem...Glad to help
Hold off on ordering and of these until I verify the part #s tomorrowor Monday. There were a few bags with part #'s that my Shop Foreman left for me and I want to make sure I am giving you the correct #'s. Something tells me I may be off.
UPDATE:
Last edited by NORTH 44 C63; Mar 19, 2010 at 10:25 PM. Reason: Incorrect Part # Supplied
