What the hell is this?
they changed gas paddle two times and checked all sensors and now they blame it on MHP Tune So they say you need to change Control unit i think New ECU it cost 2500$
so any ideas before i talk to dealer agin dealer ?i need help guys
thank
Abdullah ,,,,
Moreover, do you have the part # of the throttle sensor/ECM/throttle control module?
And the frequency was not that bad - 2x / month until I had it fixed.
It's a simple equation: you modify the car, warranty can (and usually WILL) be gone. People on shoestring budgets who can barely afford a C63 in the first place and can't afford the risk--don't modify your car. Duhhh?
No proof needed on the dealer's side other than a modification, and the burden of proof is on the owner to show the mod didn't cause the problem.
Anyway, glad the OP's problem was resolved. The shutdown sounds scary.
Was in sport mode, as I am 90% of the time. 50% throttle away from a light. Around the 2-3 shift, I got the ESC message and no throttle response. Pulled over (very lucky I was on a quiet two lane road with shoulders) and sat there a second waiting for something to happen. I did notice the idle seemed a little jumpy, which is something I haven't read in other posts. Finally, I figured I'd shut it off and restart it. Everything seemed fine after that. Drove it hard for a few more miles and no issues. Very disconcerting.
Related to this, is there a way to shut off the car and restart it while it's moving, with the keyless package? I got to thinking that I might need to do this if this crap happens again and I'm on a highway or something, vs. coming to a complete stop. I tried it in a parking lot, and when I'm rolling forward, the car would not shut down no matter how long I held the button down. I tried it in gear and in neutral.
Just this week, I probably drove 100 miles already and washed my car and was joining up with a couple of other German cars for a photoshoot. While cruising at about 35mph, this happened again and I had zero throttle response. I pulled into a parking lot, restarted the car, and it was fine.
I'll probably have my usual SA check it out today or tomorrow, but I don't have an idea of what the cause could be. I wasn't in M or messing with ESP at all in either occasion. I've also had this Velos tune for almost 3 months with over 3k miles on it, so I doubt it's related to the tune.
