C63 AMG (W204) 2008 - 2015
Upgraded Euro Console Cover Installed
Rating: Thread Rating: 2 votes, 5.00 average.
Old 08-05-2010, 09:27 PM
  #251
Tyler1012's Avatar
Renntech C63 AMG; Samoa Orange R8 GT 115/333
Got mine today!
Thank you very much Dave!
-Tyler
Old 08-05-2010, 09:34 PM
  #252
HBC350's Avatar
'18 C63A Cabriolet
Originally Posted by cbcharlie
almost got it completely installed, ran into a road block when my screwdriver wouldn't reach screws under the knob controller, i'm assuming i need to remove them all in order to get the knob off safely without ripping wires? buying/looking for new screwdriver tomorrow, ran out of daylight ;[ worst part of install for me was getting the silver around shifter off as well as the wood trim, almost there, cars in pieces, will finish tomorrow
*update, found a screwdriver that should reach ;D
Huh? Once you get the wood trim and the top plate of the console off those screws are staring you right in the face. No other screwdriver other than the torx 20 is needed. You only remove the three screws at the front (one of which holds the controller knob assembly on) the one under the coin tray and the two under the a/c vents at the rear. After that, it's pry the sides of the console inward and the part just pops off.
Here's the DIY again:
https://mbworld.org/forums/c-class-w...e-removal.html
Old 08-05-2010, 09:38 PM
  #253
cbcharlie's Avatar
2009 C300 4Matic Sport P2/MM/Steel Gray
I can't seem to get the control knob off, and I don't want to rip the wires, am I missing something? I unplugged what I thought was it but it still wasn't coming off
Old 08-05-2010, 09:42 PM
  #254
HBC350's Avatar
'18 C63A Cabriolet
You don't take the knob off per se. You unscrew the entire assembly that the knob attaches to by removing the screw under the coin box and the one just forward of the knob assembly at the front of the console. However, you still have to disconnect the white connector to the left of the shift lever and fish that connector through the console in order to get the knob assembly free from the console. That's where pulling back the carpet at the left rear of the trans tunnel comes in. You've got to free the control knob wire harness from the floorboard as it is attached with a metal clip.
Old 08-05-2010, 09:45 PM
  #255
HBC350's Avatar
'18 C63A Cabriolet
I think I've located the rubber mat that goes under the drinkholder here in the states. It's from a 2010 E63. Also, there appears to be a little rubber mat you can install in place of the ashtray (that I find useless since nobody will ever smoke in my car) that I'm getting as well. I'll keep the board updated with part numbers as I go.
Old 08-05-2010, 09:55 PM
  #256
cbcharlie's Avatar
I'll have to try again tomorrow, I didn't pull back any 'carpet', i unplugged it but I couldn't figure out how to get it through to the console ;/
All the screws are off, and the console is basically off, just can't remove completely without getting that knob off first
Old 08-05-2010, 09:58 PM
  #257
HBC350's Avatar
'18 C63A Cabriolet
As I said, unplugging the thing is only 1/4 of the battle. It's getting it free from the plastic tab just below the knob assembly and the metal clip behind the carpet that's the bear. Not bad if you know going in. Just peel the carpet back and it's staring you right in the face.
Old 08-05-2010, 10:01 PM
  #258
cbcharlie's Avatar
I'll take another crack at it tomorrow. Need day light. Thanks for the info.
Old 08-05-2010, 10:59 PM
  #259
qship5's Avatar
M5, C63, 335Ci
Disconnecting that connector is the biggest PITA of the whole process. When I did mine, the wire was hooked into a few clips that I had to wrestle with even after unclipping the connector from beside the trans shift lever.
Old 08-05-2010, 11:09 PM
  #260
HBC350's Avatar
'18 C63A Cabriolet
Yup. The plastic tab below the knob is a piece of cake compared to dealing with where they anchor the harness to the tunnel. That is best dealt with by pulling the carpet back. I could find no other way to do it without pulling hard on the wires and hoping for the best. I refused to take that risk.
Old 08-06-2010, 03:12 AM
  #261
harrower's Avatar
2009 C63, 2007 GL 450
Originally Posted by Tyler1012
Got mine today!
-Tyler
You are welcome. Enjoy!
Old 08-06-2010, 04:31 AM
  #262
harrower's Avatar
Guys, closing out the 2nd round of orders for consoles today. I have confirmed orders with required details from:
Confirmed
Faraz
PetroC55
1Lop2K5C
Dremorg
Pending
DELAWAREDAVE - I need your ship to address to complete your order
Kaiba - you in or out for console?
Will be closing this project up after this round of orders.
Thanks,
Dave
Old 08-06-2010, 10:14 AM
  #263
cbcharlie's Avatar
you pulled back the carpet on the left side on the outside part of where the shifter is?
Old 08-06-2010, 02:09 PM
  #264
Super Moderator Alumni
superlubricity's Avatar
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Arrived. Thanks, Dave.
Old 08-06-2010, 03:24 PM
  #265
SCD-1983's Avatar
2014 C63 AMG 507 sedan
Smile
HI Dave!
I got mine today as well, thank you for the great work.
Have a pleasant weekend.
Best regards
Stefan
Old 08-06-2010, 04:51 PM
  #266
Easy install. Like others mentioned, that little flat grey wire was a PITA to get out. Pulling the carpet back made access much easier.
Be careful when removing the rear vent assembly. After I "popped" mine out it went flying out of the car.
Old 08-06-2010, 06:43 PM
  #267
van_rider's Avatar
2015 E63S
Yes i had to do the same with the little grey cable that attached the MMI controller to the car. Mine was coiled with other wires so I had to pull back the carpet near the knee bolster, under the shift gate, and poke around with my fingers for 30min to loosen it out. It was a King-Size PITA.
Old 08-06-2010, 08:04 PM
  #268
cbcharlie's Avatar
I finished ;D
and damn that gray cable is a b*tch, there's no reason for it to be tied down the way it is, mercedes making my life difficult!
Old 08-06-2010, 09:07 PM
  #269
HBC350's Avatar
'18 C63A Cabriolet
The trick is in getting the little flat gray cable from the selector knob out of the metal clip that holds it to (basically) the floorboard just rearward of the gearshift. Pop the clip and things are groovy.
I see no need to put it back the way it came from MB, either. Overkill, IMHO.
Old 08-06-2010, 09:21 PM
  #270
cbcharlie's Avatar
Yea, was a pain, had to really get in there and get a good luck at it, finally got it out, then it was like 10 min of work from there.
Old 08-07-2010, 03:55 AM
  #271
kevinwithdabenz's Avatar
08 c350
waitt i just seen this is it too late to join up ???
Old 08-07-2010, 12:07 PM
  #272
cbcharlie's Avatar
might want to pm 'harrower' and see if he placed the order yet.
Old 08-07-2010, 12:32 PM
  #273
Mort's Avatar
PM harrower, ASAP, and ask as he is just finishing up the second round of orders.
Old 08-07-2010, 12:34 PM
  #274
Mort's Avatar
Mine arrived as well!
Thank you
Old 08-07-2010, 02:09 PM
  #275
Mort's Avatar
Installed!
Thanks to HBC350 for the helpful hints on the gray wire. They are invaluable.
Thanks many many times again to harrower for the huge amount of time and effort he put into this project and for making this mod possible for us all!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: Upgraded Euro Console Cover Installed
