C63 AMG (W204) 2008 - 2015
awful 1/4 mile times
Old May 14, 2010 | 09:09 PM
dmyrick's Avatar
C63
went to the local track today and it was brutal. all but one over 14 sec. my best was a 13.94 and my best 60 2606. my major stupid moves AC on Esp on had new Michelin protenza tires just installed yesterday please constructive information only.
Old May 14, 2010 | 09:17 PM
C63newdude's Avatar
C63 AMG
Don't worry. I know you have a huge margin of improvement. What was your trap speed? Your 60' should be at around 1.9 or 2.0 for the average C63 owner with bone stock car. Your 2.6 sec 60' is killing you.
Typically a tenth of a second on the 60' equals two tenths less on the ET so I can easily see you at around 12,8-13.0 sec ET in no time. Best of luck!
I recently improved my times slightly using M mode, traction control off and launching at around 1700rpm. I was shifting when the red shifter lights lits.
Old May 14, 2010 | 09:25 PM
dmyrick's Avatar
C63
it felt faster. especially when i lined up against a ricer in a honda he took off on me with about 2 car lengths and i caught and passes him with about 2 car lengths at the 1/4 line he just took off even though we spent 20 bucks for track time.
Old May 14, 2010 | 09:34 PM
C63newdude's Avatar
C63 AMG
The 60' and trap speeds will tell us a lot. What was your average 60' and average trap speeds? Looking at your 2.6 60' I can tell you already what the problem was. A 2.0 60ft will put youright in the high 12's
Old May 14, 2010 | 09:37 PM
HIRO63's Avatar
c63
One more thing is that I think that since you changed your tire yesturday so I dont think that you are getting the best gripping area yet. So if you get to that area you should get more grip at the start and get more good time.
Old May 14, 2010 | 09:42 PM
dmyrick's Avatar
C63
my best 60 was 2.60 worst well in the 3.0's
Old May 14, 2010 | 09:59 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Don't worry. I went to a drag strip the 1st time about 2-3 weeks ago. Made 10 passes and couldn't get under 13 until the last pass with 12.990. Just got to practice the launch more and more.
Old May 14, 2010 | 10:03 PM
dmyrick's Avatar
C63
I have lsd i think it will make a big difference once i turn esp, oh and i used 100 octane gas
Old May 14, 2010 | 10:25 PM
kustom2k1's Avatar
03SL55
You wont get any benefit from 100 oct unless you have the tune setup to run 100 oct. Your 60's tell the story, you need to lower the tire pressure to 24lb and do a little burnout...stage then roll on the throttle gradually out of the hole, by the time the engine is spinning around 3500 you can just flat punch it. I ran with a C63 at the track and he was at the 60ft in the 1.9s and ran in the 12.30 range consistently (ECU tune) with traction control off.
Keep going to the track, you'll get the hang of it!
Old May 14, 2010 | 10:30 PM
dmyrick's Avatar
C63
Thanks guys good info for my next runs.
Old May 14, 2010 | 11:31 PM
racxr.x's Avatar
2010c63
u suck at driving, who the f turn on their esp and launch the car at the the drag strip, if you are scare of fishtailing ,at least put the car in sport mode so esp won't cut power on first or second gears. you will have faster times but u need to turn off esp and put it in sport mode.
Old May 14, 2010 | 11:44 PM
c63canada's Avatar
c63 amg
IMO Maybe think about lowering the tire pressure in the back for a better launch.
Old May 15, 2010 | 12:17 AM
dmyrick's Avatar
C63
it was in sport mode. i didn't turn esp on genius i just forgot to turn it off.
Old May 15, 2010 | 02:58 AM
C63newdude's Avatar
C63 AMG
What was the trap speed?(I asked this 3 times now)
Old May 15, 2010 | 03:17 AM
Boost Gomez's Avatar
C63 AMG
He probably has no idea.
Old May 15, 2010 | 04:12 AM
MB_Forever's Avatar
E63 P30, CL500 Sport
Which track did you go to? What was the elevation, temp, and weather conditions? DA could have played a role in your numbers as well, so the end numbers don't tell the whole story.
Old May 15, 2010 | 10:15 AM
jmf003's Avatar
'03 SL55
Try using less throttle on launch...in particular try taking about 1 second to go from idle to wide open throttle.
When you use too much throttle too quickly you'll either wind up spinning the tires (when ESP is off) or causing the ECU to apply the brakes and reduce power (when ESP is on). Either way, it slows you down.
With practice you should be able to run sub 2.0 second 60' times, which will greatly reduce your 1/4 mile elapsed time.
Good luck!
Old May 15, 2010 | 11:31 AM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Are you sure you were in ESP sport and not just sport shifting? That would really make sense. Turn it completely off next time and practice, it's not that hard to launch.
Old May 15, 2010 | 12:20 PM
dmyrick's Avatar
C63
my trap speeds were 107s and one 108
