CRUISE CONTROL INOPERATIVE ...
This was the 1st message before my ECU self destructed.
Regards
I then checked my "messages" and there were none.
It only happened once and like I said the message wasn't even accurate because I was able to use my cruise control just fine.
Tried it today and it worked fine. The message is gone too.
Is this happening in cars with stock tunes too?
I've been using cruise control since 2009 and this never happened before. Any thoughts?
To the people who have encountered this, is it a one time thing? Or should I expect to see this again?
Thanks in advance
Thanks in advance
I just got that message this morning, restart the car and message gone,
but OBD II reader shows a few error code (no CEL though)
U0121
U0415
P1369 - engine temp sensor/cylinder 5 ?
P1373 - cylinder 7 ?
any help would be much appreciated.
1. Try turning "dyno mode" on it will turn off all electronic assists then turn back off. (Reset)
2. If your car has ESP (Traction Control) off Cruise will not work.
3. Check for any warning lights on dash
4. Check fuse box (I think it's in trunk) for cruise fuse.
To get the car into "Dyno Mode" first turn the car 2 clicks so the aux power is on, then hold the "ok" and call answer buttons on the steering wheel at the same time. After 3 or 4 second a menu will pop up. Select "dynamometer Mode". Turn on then start the car drive around the block. (ALL SAFTEY MEASURES ARE DISABLED!) This mode is equal to (track mode) you can BURN the tires off so be careful lol. Then turn the car off, then when you turn to aux again turn off. Take the key out then everything that works should turn back on.
(Check the secret menu it has a lot of info on the cars condition, services etc)
Good to know. I will test a couple of your suggestions.
