C63 AMG (W204) 2008 - 2015
So I am driving my loaner car....
Old Jul 15, 2010 | 12:19 AM
FBTO's Avatar
2010 C63
So I am driving my loaner car....E550C!
And it was an E550C! Pretty sweet ride.
Would be a great sub if I didn't want all that performance.
But the one thing I noticed is that the paddles shift seem much faster than my C63!!
Much!!
I know so of you mention that the car learns your driving style. Does this car have the transmission as the C? And if yes, how do I train my C to shift like this E?
Old Jul 15, 2010 | 01:52 AM
arctichaze's Avatar
C63
It's probably a better tranny which is usually reserved for anything that is not a C class.
Old Jul 15, 2010 | 08:36 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Generic C class yes, but are all the 63's using the same tranny across the MB lineup?
Old Jul 15, 2010 | 10:04 AM
GMW's Avatar
GMW
2013 ML63 AMG PP
The C63 is fitted with the rather nice AMG SPEEDSHIFT PLUS 7G-TRONIC automatic transmission. Hence the blips in S & M mode and sounds like a dinosaur....gurgling gravel on when letting the engine slow the car down by itself. It is not the same as in the standard C-class.
I drove the E550 (E500 European version) in Europe and the gearbox was not faster than my C63. It sounds like you need to reset your transmission memory and clean out it's cobwebs.
Old Jul 15, 2010 | 10:55 AM
FBTO's Avatar
2010 C63
How do you reset the transmission memory?
Old Jul 15, 2010 | 10:59 AM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
+1
Old Jul 15, 2010 | 11:00 AM
jvanbrecht's Avatar
I'm not aware of the ability to reset the transmission. However, you can reset the adaptive throttle control.. (search for it, its mentioned here a few times, I cannot remember the sequence)
Old Jul 15, 2010 | 11:04 AM
drawde's Avatar
2009 C63
this one?
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Old Jul 15, 2010 | 11:21 AM
jvanbrecht's Avatar
That would be the one, but that has nothing to do with the transmission, that is the ATC which I find annoying my driving styles change radically depending on traffic and conditions.. I wish I could just disable it, set it to the most aggressive setting, and leave it :P
Old Jul 15, 2010 | 11:54 AM
Originally Posted by drawde
this one?
I thought this didn't work for our cars (08+)?
Old Jul 15, 2010 | 01:38 PM
GMW's Avatar
GMW
2013 ML63 AMG PP
this one?
Yes that's the one! I believe it works on all models. Try it out then report back. I have only reset once, a while back, otherwise almost everyday my rev counter passes 7,000rpm at least once.
Old Jul 15, 2010 | 01:44 PM
FBTO's Avatar
2010 C63
How do u know if it did anything? Where will see the difference?
Old Jul 15, 2010 | 02:30 PM
Questions's Avatar
C63
Seriously. Thought the M3 was too complex...but I guess that's what we're looking for with the adjustable settings.
Either way, Sport should be SPORT
+1 This isn't supposed to work with 63s...
Old Jul 15, 2010 | 03:05 PM
drawde's Avatar
2009 C63
Might be placebo but the last time I did it (a WHILE ago) I noticed something.
Old Jul 15, 2010 | 03:26 PM
FBTO's Avatar
2010 C63
What did u notice?
