Nitto 555R 285 35 18
I agree with EM. It will likely rub the inside fender lining if lowered.
They are rated for the correct load rating just not the MPH...
I guess it doesn't matter if you drive less than 168mph...
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
I paid for my pair $684 for two ater all the BS of taxes, balancing, dispossal of old tires, etc, etc. I personally don't recomend them. I cut only do 2.0 sec 60 with my current mods(see signature). I have done much better with the older Nitto 555S which have a threadwear of 400. Like I said , I DO NOT recommend them.
