Whos car is this?
Whos car is this?
I just love how this car is lowered and just wanted what he did to this car.
KW coil over? H&W spring?
I want to lower mine this much
1 Post
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
I remember this pic, The guy wanted to sell his C63 and that was at least a year ago.
1 Post
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
In the front yes, but in the back the height is not easily adjustable, you would need to compress the springs to go that low. Still take into consideration that if you have friends in the car or stuff in the trunk, being that low in the back will cause some issues.
if you are going to track the car then go with the KW's . if you just want the drop for the looks and not going to race the car a lot , then go with H&R coilovers . they are about half the cost of the KW's . H&R has great products and i have always preferred them .
If you only care for looks, than go for this set up. I thought you take your car to the track, but could be mistaken? If you do, forget about the fast tracks. The car is way too low in the rear. I know it looks good, but handles for lack of a better word, like crap. Not only will it have massive understeer, but in a long fast sweeper, the rear will hit the bump stops. At 120, not a particular confident feeling behind the wheel. If I recall correctly, you also run a big wing in the rear, which will compress the rear suspension even more. It's a 4000 pound car and all that mass at speed needs to be absorbed by the suspension. Hence, the ride height can't be too low so there is some room for suspension travel.
All this information is of course just a friendly suggestion
Hey guys thanks, yes I do track the car little so I should forget the set up for sure. Like everyone say it may look good but handling must be not good. thank you everyone.
