C63 AMG (W204) 2008 - 2015
Catch can to solve oil drinking?
Old Aug 23, 2010 | 01:48 AM
AlexCim's Avatar
2011 Ultima GTR
Was speaking to a local tuner here in AUS and he was telling me (he owned a C63 before) that he thinks its best to install a catch can on a C63 to help it stop drinking so much oil.
His theory/explanation went along the lines of.
- The car drinks oil
- Its breather system is not that great and it puts a lot of oil into the intake manifold, to burn it
- The manifold gets oily, car burns oil, results in the smoke/soot from exhaust and obviously drinking oil
- Fix this by fitting a catch can/breather can to condense the oil vapors...
Results in improved performance (Overnight oil from the intake manifold settles in at the bottom, gets "sucked" into intake a some point or when car is turned on) and less/no more oil drinking.
Having spoken to another tuner, they've mentioned that they havn't done or heard of this before, and they even have a CLK63 as a track car.
So, anyone got experience/feedback/information on installing a catch can on a C63. Yay or Nay?
Old Aug 23, 2010 | 02:46 AM
bhamg's Avatar
C63 AMG
Perhaps the people who have done the intake gasket replacement mod can weigh in on what they saw.
Old Aug 23, 2010 | 05:57 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
simple easy mod, cant hurt. I have one on my E55
Old Aug 23, 2010 | 06:45 PM
dremorg's Avatar
2015 Jaguar F-Type R Coupe' '99' Audi A4 Avant Quattro 2.8 DD
I'm for any type of improved performance? How though?
Old Aug 24, 2010 | 10:24 AM
Mort's Avatar
How often do you drain your catch can and how much oil do you get out of it?
Old Aug 24, 2010 | 10:39 AM
Boost Gomez's Avatar
C63 AMG
How many miles do you have on your car? After 10,000 or so miles, my C63 has stopped drinking oil.
Old Aug 24, 2010 | 11:03 AM
shardul's Avatar
I can only speak for my motor. about 10 to 15ml every 5 to 7k miles
Old Aug 24, 2010 | 05:16 PM
Mort's Avatar
Thanks for the information. This is not a must do mod on an NA motor but not a bad mod to do either. A build up of oil inside the intake is not ideal and can lead to some problems and perhaps even a little knock if bad enough. This is a more necessary mod with FI when rings wear and blow by increases causing even more oil to be pushed into the intake.
My Chev 6.0L truck has been turbocharged for 5 years and 54000km and it still gets by fine without a catch can. As long as the rings are sealing well it is not too much of a problem.
As Boost Gomez says these engines seem to seal up pretty well after 10000 miles or so when the rings are fully seated.
I don't think there is too much of a performance advantage to adding a catch can to the PCV system if your engine is in good shape otherwise.
Old Aug 24, 2010 | 06:46 PM
bhamg's Avatar
C63 AMG
I'm interested, dating back to considering this on another car. Does anyone know if there is a ready-made catch can for the 6.3 for sale by a vendor?
