C63 AMG (W204) 2008 - 2015
Burn outs
Old Sep 1, 2010 | 02:00 AM
allenc63's Avatar
2012 CLS 63 AMG P30 Palladium Silver , Weistec Tune, Weistec Air Filters
Burn outs
How do you fully disengage traction control in order to do a burn out
Old Sep 1, 2010 | 02:20 AM
blilley18's Avatar
2011 C63 "The Beast"
hold down the traction control off button until on the display in the middle of the speedo it says "traction control off". then to do a burnout hold down the brake, gently put on the throttle and balance throttle and brake until burnout is achieved. to "roll out" release brake completely and do full throttle
Old Sep 1, 2010 | 02:25 AM
allenc63's Avatar
I appreciate the help, but even holding down the traction control button doesn't fully disengage it. I heard somewhere about a hidden menu in the trip function of our command center. Winthin there is an option for full disengagement.
Old Sep 1, 2010 | 02:28 AM
Mantooth's Avatar
2004 E55 AMG
If it's anything like the C55 and E55, you can put it in dyno mode.
It's too late for me to give you a play by play, so I'll just link you to the thread...
http://www.benzworld.org/forums/w211...into-dyno.html
PS: Dyno mode is expensive and dangerous. I love it!
Old Sep 1, 2010 | 02:33 AM
Even Money's Avatar
'15 VW GTI
You press the ESP button on the center console until you see ESP OFF on the display. Then, it is fully disengaged....
allenc63's Avatar
perfect thanks
Old Sep 1, 2010 | 02:40 AM
blilley18's Avatar
yeah thats what i meant. u dont want to turn on dyno mode though because that disables things that have to do with steering along with esp
Old Sep 1, 2010 | 02:47 AM
Mantooth's Avatar
2004 E55 AMG
Does it differ from the E55 to the C63?
In the E55, ESP off doesn't mean it's completely disabled. Can overheat your brakes really quick by doing a burnout like that.
In the E55/C55, dyno mode disables the ABS. I've driven around in dyno mode without any problems. Just have to remember to brake a bit earlier.
Old Sep 1, 2010 | 03:03 AM
blilley18's Avatar
probably because the brakes are a lot larger in the c63. yeah when me and my dad got our car dynoed it said something about abs and esp on the sceen. might have been something else too im not sure
Old Sep 1, 2010 | 03:08 AM
Mantooth's Avatar
2004 E55 AMG
Go to an open parking lot, put it in dyno mode, drop it down to first, in sport mode and give it hell. Be sure to bring a flat bed or a spare set of wheels/tires.
Old Sep 1, 2010 | 02:16 PM
allenc63's Avatar
Ok will do I will post video when done...
Old Sep 1, 2010 | 02:38 PM
badblackbenz550's Avatar
benzo larenzo
i drive in dyno mode on daily basis...
Old Sep 1, 2010 | 02:40 PM
callmiro's Avatar
2016 C63 S
In the C63, "ESP OFF" is completely off and completely disabled. There is no need to mess around with Dyno mode for a burn out
http://www.youtube.com/watch?v=-lGyn...eature=related
Old Sep 1, 2010 | 04:44 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I'd echo the keep-away-from-dyno-mode sentiment. ESP off / Sport / Zooooooommmmmmmmmmm
Edit: ESP off / Manual / Zooooooommmmmmmmmmm
Old Sep 1, 2010 | 05:13 PM
emericr's Avatar
2021 Porsche TTS
C63 is different than E55. You can disable ESP when it is set on OFF. Then do your burn out and get ready to go to the local tire shop because your tires won't last long. It is a lot of fun and you gotta pay to play
Old Sep 1, 2010 | 06:37 PM
propain's Avatar
See Sig
Why?
Old Sep 1, 2010 | 06:43 PM
Mantooth's Avatar
2004 E55 AMG
Thanks, guys. Did not know this.
Lucky ****ers.
Old Sep 1, 2010 | 07:00 PM
mthis's Avatar
Anything W/4Wheels
here is how you do it.
hold the gas and brake at the same time and make sure you in (M) once you bouncing off the rev limiter upshift to 2nd gear and let go of the brakes and keep switching gears if you want just be care full bc its very very very dangerous
here is what i came up with 1-2-3-4 gear the longest burnout that i have seen on a c63 have fun and be safe
http://www.youtube.com/watch?v=9n67f-T1g3A
Old Sep 2, 2010 | 07:10 AM
Mort's Avatar
Nice one
Old Sep 3, 2010 | 01:53 AM
allenc63's Avatar
Well that was a $500.00 burn out . Hopefully thay were old tires. BUT VERY COOL
Old Sep 3, 2010 | 09:52 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
I'm about to replace my tires, rears are almost completely bald.. curious how much of a burn out I could do on those before they explode on me... heh.. stock pzeros..
Old Sep 3, 2010 | 02:20 PM
cyberorth's Avatar
2018 AMG GTR, 2017 GLS63, 2019 C63s
Hey you just bought new tires. Move along...
Old Sep 3, 2010 | 04:19 PM
emericr's Avatar
2021 Porsche TTS
jvan: I was wondering the same thing. I was thinking of letting it rip before I get my new tires but did not know if somehow the tire could blow out... Good question.
Let's see if someone has an answer
Old Sep 4, 2010 | 08:43 AM
Walnuts's Avatar
2010 C63 AMG (Marrano Tune and K&N airfilters)
http://www.youtube.com/watch?v=PTFzF...eature=related
Now thats how you do a burnout. Doesnt matter how many times i watch this i just never get sick of it.
Old Sep 4, 2010 | 09:34 AM
mthis's Avatar
Anything W/4Wheels
When I did the burnout above I had tread showing on the inside of the tire and the tires still lasted for that burnout and I made it to the shop to Install my new tires.
