X Pipe, Magnaflow sounds.
I just refuse to pay $700 for a small piece of bent pipes
Our Single X is $649.00 BTW, and is far from a few bent pipes, it is not easy to build them, it is actually quite a complex piece to build correctly, it uses a few compound bends, everything is mandrel bent, and all measurements are exact (see photo of our new 3D pipe modeling process) coupled with a difficult mating flange compression joint and a lot of labor intensive TIG welding on expensive USA Stainless Steel, I just refuse to have them made in China... I understand you not wanting to pay this type of money, not a problem, I can understand your concern, and wanting to save a few $$, nothing wrong with that. There are other companies out there however that get PREMIUM for their items that are priced FAR higher than mine in terms of cost/profit ratio.
It sounds like your exhaust components are top notch. Does this x-pipe bolt right up to stock system or does the stock system need to be cut and your part welded in?
Does the x-pipe affect the AFR if nothing else on the exhaust side is changed and the rest of the car is stock? If so, would it make the car run more rich or lean?
Does installation of this part cause ANY drone. Is the factory sound maintained, just made louder?
Thank you for taking the time to read my questions.
