Oil Level *pics*
Btw. make sure your car is on a level plane (no inclines), so your oil reads accurate on the dipstick.
After the first oil change at 1500 Mi it read at the top of the minimum red marker.. I assumed this was ok, and I have never added oil.
In any event I would always add 1/2 qt. until I knew exactly what this would read.. According to your pic, you should have been ok with a qt. added.. As long as you arent bellowing blue smoke and misfiring you should be ok.. This oil thing is crazy with the AMG as the manual doesnt even show the correct dipstick and some engines burn and some don't . How many miles on your car??
Are you supposed to check the oil when the temp is at about 215 degrees or can you still get an accurate reading when the engine is dead cold?
You'd have to be plain retarded to add so much oil that the level gets up past the counterweights to the rods.
That said, I'm sure the whizbang 6.2L has a full windage tray, yes?
BTW, connecting rod's consist of two pieces. I was talking about the part that's connected to the crankshaft, not the piston
I had my first oil change at 1000km, and my oil is at the minimum level on my dipstick at 1500km... but again I always check the oil when the engine is cold... do you think it will have a big difference in the readings with a warm engine? should I go to the dealer to have it top up?
wow, thank you so much for that revelation. I had no idea rods were two pieces.
However, as I'm sure you realize, the rod cap extends maybe 1/2" from the crank journal, while the crank counterweight is typically 3" or so past the journal. So now, you tell me, what would hit the oil first?
