C63 AMG (W204) 2008 - 2015
painted side reflector ; Glowing yellow light
Old Oct 11, 2010 | 12:52 AM
451HP's Avatar
2010 C63 AMG (Iridium Silver)
Ok, so I've just installed painted (Iridium Silver) side reflectors and like many said, the yellow light is glowing around edges.
I've searched for reflectors and bulbs, and notice that some ppl use electrical tape, painting or zipping? but still can't find clear winner to let this light disappear. Anyone actually used any of this method and had successfully got rid of glowing light please let me know how you did. TIA.
Old Oct 11, 2010 | 09:24 AM
OrientBlue3's Avatar
ED1 e63S
Subscribed.
Old Oct 11, 2010 | 12:09 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Can't you just removed the bulb? That's what I did on my Lexus, and no warning light on my dash... not sure about the benz though.
Old Oct 11, 2010 | 02:59 PM
BAD430BENZ's Avatar
360 Modena TT
just remove the bulbs . i removed mine and when the car starts , i get the warning light but just press "OK" on the steering wheel and it goes away . pretty simple fix
Old Oct 11, 2010 | 03:04 PM
C63Dude's Avatar
C63 AMG
Just destroy those useless bulbs...
Old Oct 11, 2010 | 08:18 PM
jafores's Avatar
08 C63, 07 ML63, 92 500E, 70 300SEL 6.3, 63 220 SEB Conv. Sold 02 G500, 97 E50,92 C280,71 280SE 4.5
Did you paint the inner edges of the reflectors? I sugest you paint the that area with black paint then top coat with silver this solved it for me. If you still experience bleed thru then you can also paint your bulbs just use heat resistant paint (for the bulbs) to be sure
Good luck
Old Oct 11, 2010 | 09:47 PM
sighting's Avatar
e63s edition 1
hmm why dont you just stick a resistor on in place of the light?
Let me go find the replacements i have and test them to see the ohm needed.
UPDATE: ok so why cant you just put in a simple 25cent 5w 4ohm resistor in it's place?
I am sure we could get away with larger or lower values but the bulbs seems to test 4 ohm at 5 watt.
The ECU might only look for the watt or ohm part not sure if it needs both.
The holders should hold up well to folding the steel ends of a resistor over in a loop and plugging them in.
They should not pop out even under the G's we put on them.
If anyone has some spare resistor lying around please test for us.
I am digging around myself.
The colors we after is "Black Yellow Black Gold"
those with electronics degree please chirp in here.
Old Oct 11, 2010 | 10:04 PM
451HP's Avatar
Thanks for the suggestions...So obviously removing the bulbs sound like easiet fix and...it's confusing why some ppl still use electrical tape, paintings, etc???
Old Oct 11, 2010 | 10:14 PM
sighting's Avatar
e63s edition 1
removing the bulbs throws an error on the console. you have to click OK to cancel it every time. That is why we thinking of other ideas..
Old Oct 11, 2010 | 11:07 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
I painted mine with high temp spray paint (available at ANY auto parts store). Worked perfectly. Don't just take the bulbs out.
