C63 AMG (W204) 2008 - 2015
c63 chugging violently
Old Oct 24, 2010 | 07:14 PM
sighting's Avatar
e63s edition 1
as i mentioned it sounded allot like bad gas... as long as you got it solved.
it's all that counts..
Old Oct 24, 2010 | 07:27 PM
mthis's Avatar
Anything W/4Wheels
Originally Posted by Sonny@Marranos
I will get the part numbers for you tomorrow as we have replaced quite a few o2 sensors on c63's,& yes race gas doesnt help either,its shortens their life span quite quickly,Contanimation is another killer for 02 sensors,ppl put all sorts of home remedy solutions down their tanks,that was oki in 70 80's,these days alot of the modern cars have wide band sensors for precise fuel control at 0 to 90% throttle conditions.
regards sonny
Tnx Sonny.
Old Oct 25, 2010 | 06:59 AM
amgph's Avatar
c63
Thats ridicolous,its easy to log upstream o2 activity and easy to tell if they are functioning correctly,if they cant do that as a merc dealership,they might as well shut shop ,get someone independant that knows how to use a logger and log o2 activity when it chugs & you will know right way which o2 sensor it is.
regards sonny
yes i agree mercedes ecu log all faults these days even when the fault goes away it still leaves a code in the ecu so you can download and problem shoot
Old Oct 26, 2010 | 07:22 AM
GMW's Avatar
GMW
2013 ML63 AMG PP
I had a similar experience shortly after putting some fuel in my tank that was close to empty. It chugged like crazy the next morning but as it turned out, it was bad gas. I noticed the return to normal after putting a fresh full tank from another station. Then the chugging disappeared.
The only slight hesitation I can get now is if I try to accelerate hard when the engine is cold at around 3,000rpm+, which is something I shouldn't do but I was in a situation where if I didn't accelerate, there was going to be a spectacular accident.
Old Oct 30, 2010 | 12:00 AM
blackc230benzo's Avatar
2010 C63, 2003 C230 coupe
Solution!? I think.
Thought it was bad gas, drained tank, refilled with another 94octane still chugged.
Went to dealer, no CEL but they were told by AMG to replace cam position sensor. Still chugged.
Removed the brand new BMC air filters and replaced with stock, Chugging 100% GONE. Will retry BMC's on monday after they sit out for a couple days.
Hopefully I either didnt tighten the air boxes enough, or the filters were too oily. If not I just wasted $200 on air filters.
Or is there such a thing as too high of air flow? and something needs to be recalibrated for higher flow filters?
Old Oct 30, 2010 | 01:19 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I told you bro about your new filters. I hope the dealer didn't charge you for the cam sensors?
Old Oct 30, 2010 | 01:21 AM
  #32
Roswell's Avatar
I'm not sure about our Benz, but on my Lexus I had to reset the ecu after changing my intake & filter.
Old Oct 31, 2010 | 08:09 PM
  #33
c63canada's Avatar
c63 amg
Originally Posted by LZH
Have them check the cam position sensor.
had mine changed
Old Oct 31, 2010 | 08:51 PM
  #34
Originally Posted by c63canada
had mine changed
I had the cam position sensor changed already and there is still a chug around 120.
I put the stock paper filters back in and the chugging is gone, then re-installed the bmc's and disconnected battery terminals and chugging was still there.
Then put in 1 paper and one BMC and the chugging came back with a CEL code p010B and p101 mass air flow issues, swapped filters to see if it was a certain MAF sensor but same code, same chug.
Might just give up and go back to stock papers, I would just like to know why it is happening with the high flow filters.
-I know there is another thread of mine with this issue, it was opened more recently with more focus on the filters.
