C63 with Oe-tuning 1/4 times
And I did get to 12.42 which is #3 overall for all C32s. Not bad for a 3.2 litter SC V6.
And to Jon, I think you may have finally got it. It's you. You do need some more practice. Remember, this is not braket racing. Don't worry about your reaction time. Right now it's all about your 60' time. Then you will see what your car is capable of.
That just shows the kind of classy guy you are. Not many (if any) would even bring it up in public or in private. I'm not mad at you at all. You gave me a sound technical advise and I followed it. I don't think I can be pushed into anything (unless I'm alone with a young ****). I'm actually very happy that I got to know you and Hagi. And it's not the track records. It's the way you carry youself when not running your car. True leader.
I'll be back next year. You can count on it.
and calm down on your
Another ironic side to all of this is that he was also arguing about oldgixxer's 11.9 second stock run in his E63, which was ran at the same track with similar conditions. Not only did he not come close to oldgixxer's record.... but oldgixxer actually cut a better 60' time on sh*ty continental stock street tires using a heavier (and allegedly slower) car than Jon did on drag radials
He may need to get a baby seat to match oldgixxer's record on street tires
http://www.youtube.com/watch?v=d5TOGO4noJA
Jon,maybe you should line up with oldgixxer&see whats up? Hes in NY too I think
Hagi,Propain,or Mike can vid the run
I ran in 64F thats 24F difference. Like I said I did bog. Maybe its the tune or my driving.
From a roll there is no driver error so bring any stock e63. I'm not saying who is going to get raped. Let the video speak!
And BTW,you never replied to my PM about your car vs my GSXR-600..I was giving you 5 car lengths&the break if you forgot..I had it at MIR saturday,its not that fast&I think it'd be a good run
Link for Go Pro special
https://mbworld.org/forums/c63-amg-w...y-special.html
Who nos maybe I can line a little something up between 5 and 7:30 after work!!
Oldgixxer's run was actually at 45 F and some of your first runs (on street tires) were at 50 F, so conditions were similar early on in the day. Apparently your first few runs on street tires ranged from 12.4 to 13.1 and you didn't get into the 12.1s until things started to warm up. But notice that even when temps did warm up a little (near 60-65 F), conditions actually gave you the advantage NOT to oldgixxer in terms 60' time (even on street tires) since generally speaking 60 F environment causes the VHT to stick much better than in 40 F environment. In addition to the more sticky surface, you had yet advantage (again in terms of 60') when you started using DR (later in the day). However, with all those advantages on your side, you STILL DID NOT BEAT his 60' time. So lets see.... you had the following advantages:
1) You ran in 50 F to 63 F temps, which are about 10 to 15 F warmer than temps during oldgixxer's run but it actually favors traction because it allows the VHT stick much more than in 40 F.
2) You tried drag radials many times but only got one run in the 11s and even on that run, you didn't beat his 60' time. The rest of the runs were all over 12 seconds.
3) You had a lighter car (and lighter driver) with a fairly aggressive tune (meaning more power than even a stock E63) yet you still did NOT beat his 60' time and could only beat his ET record using drag radials.
Do you think in 40 F or even 35 F, you could still cut a better 60' time and better 1/4 mile run on stock tires, filters, etc... ? I have a feeling that if oldgixxer was indeed at ATCO, he would've annihilate you run after run (at least for most of the day).
-so ur not willing to run the 600?
-whats ur buddy w a 850hp vette have to do with this? Is that supposed to scare me?
and the only board member that proclaims over&over&over&over that he owns a "factory freak" is you...no one else
I've noticed some E63's can cut 1.7's on stock tires, definitely 1.8's. So, what's the deal? Why can't tuned C63's do the same thing?
