Stock air boxes for 63
Yes, no reason to speculate about the power loss without the dyno with the new tune.
You should Dyno with the Airbox mod intact first though and then with the stock to compare.
Yea I'm going to meet Albert there see if we can do a few runs with both boxes and I removed the carbiono from my car to try that to!!
Former Vendor of MBWorld
The modifications made to Albert's header were very small. The nut on the steering column was touching the header at certain angles when the steering wheel is turned. I put a small dimple in the downpipe to make clearance for the nut that was touching slightly when the engine was torqued under heavy acceleration at certain steering angles. The dimple that was put in the downpipe was very minimal. There is a lot of misinformation out there in regards to this header install. I would definitely rule out any install issue related to a modification made to the headers. I do not think that the dimple was more than 2mm deep, it is very slight just to add a little clearance for the steering column nut.
It is hard for me to comment on any of the dyno charts because I was not there and do not really know the actual details of what the settings were on that particular dyno. The torque graph was very unstable but supposedly the smoothing was set on the dyno. If it was set I would not have expected to see a torque curve like that. Cory may suspect that the car was experiencing some detonation and also dumped a little fuel while pulling a lot of timing as evidenced by the torque curve but, like I said, I cannot and am not trying to state anything in regards to that, I was not present and I have never used that particular dyno but from what the sheet shows that makes a lot of sense.
The dyno that Albert is going to tomorrow is one that I use for my customers quite often and a lot of Benz's have been tested on that dyno. As a matter of fact, Albert had his car on this dyno after receiving his tune but before doing his header mod and the car made 405 horsepower. So we do have a dyno sheet on this dyno's computer that we can use to overlay a new graph from the old set up to get some kind of comparison. Obviously there was a big difference between the 405 horsepower pull and the 424 horsepower pull (I believe that was the number) between the two dynos with no changes to the car. Hopefully tomorrow we will be able to compare two runs and, at that point, I would suspect may be a smart time to look into Albert's car for any further problems that it may have.
I think it is kind of premature to continue guessing what problems the car may have and it is silly to not wait until the car has been tested with a Kleemann tune. Kleemann is confident enough, that the headers cannot lose this horsepower, to tune Albert's ECU and offer a full refund if it does not alleviate his problem. Albert also was fortunate enough to receive a free set of Kleemann headers to test fit them on his car to make sure that they fit well on the 212 chassis. At $2795.00 for Kleemann headers that Albert was originally gonna pay had they made a set specifically for his car, that is a gracious gesture from Cory.
As a Kleemann dealer I cannot say enough about the service that Kleemann offers its customers and its dealers. I have been happy with the products that they offer and they provide me with a great product to offer my customers that i can confidently sell and know that my customer has a quality product on there car that will not result in any premature or unwanted failures.
Albert is always asking me questions and for ideas to calm his nerves as he asks the forum members as well, sometimes it is best to take things one step at a time and to follow a procedure when diagnosing and modifying certain aspects of your car. I have only used an engine dyno to tune my race car engine and other than that I rely on the drag strip to test any changes that I have made to my cars. My ultimate goal is to go quicker and faster and I find the best way to do that is to test what I do at the drag strip.
I am confident that Albert's header installation is not the culprit for a loss as significant as he is experiencing, I am very well aware of many header installs from Kleemann that have shown significant gains in horsepower on other chassis 63 vehicles and Albert's car should be no exception. Albert, don't worry so much about this, we know your car is now running at a different air fuel ratio and your car is very safely tuned, get some sleep tonight, don't let this stress you so much, tomorrow is your first dyno day since your new Kleemann software has been installed, I think you are in good hands. Let's see what changes happen and we can go from there, it is the best advice I can give you.
It is good that the forum knows what goes on so that members can learn from these things but it is important that certain things are done in certain ways when diagnosing these problems. For people to say that the headers are leaking, and the dyno shop told Albert that the gasket in the header downpipe may be installed backwards and is blocking the airflow just leads to ridiculous conclusions sometimes. A header leak is an easy problem to diagnose and one that we check for before any car leaves our shop that just had headers installed. As for the gasket problem the way that Mercedes Benz built the exhaust prevents any type of problem like that from existing.
I hope that problems like these lead to all of us improving upon our own vehicles, that is what it's all about.
E63 AMG 2010, Black, Pano, P2
#32
I will not dyno my car ever!!! Sorry
#33
E63 P30, CL500 Sport
+1.... Nowadays with the computer controlling the engine power and having to deal with (and respond to) thousands of variables, results and data obtained on the dyno may not equate to results and data obtained on the road. Unfortunately (and like many others), this have kept me up at night scratching my head trying to figure out what happened
#34
+1.... Nowadays with the computer controlling the engine power and having to deal with a thousands of variables, results and data you get on the dyno may not equate to results and data on the road. Unfortunately (and like many others), this have kept me up at night scratching my head trying to figure out what happened
#36
#37
This is a very important point. I know dyno owners and operators will say dynos are great and often times they are, but when you consider the very valid point that you raised, it's just becoming more accepted that dynos are not gospel and often become counter-productive (not sure if supposed to hyphenate that word) to many of our performance aims.
#38
QFT.
#39
i willl ad my 2c to this thread. Stock i made 270rwkw (12.6 @ 112mph), tune i made 325rwkw (12.2 @ 115.5mph), with car graphic exhaust 305rwkw (11.9 @ 119mph best of 121mph). My dyno numbers are all over the shop, but with more mods ive gone quicker and quicker. hope it helps
h.
h.
#40
In my opinion Dyno numbers are still very much a part of tuning a car. Yes you may not get the results you think you will get based on the numbers your seeing on the Dyno, but seeing how your car is performing and where the power is coming on and dropping off and tweaking from there is an integral part of tuning a car.
#41
Oh how the world has changed...
#42
I like looking at results on the Dyno, But as my man Bruce from TTM says real world conditions can change everything.
#43
No offense to you Craig, but this situation is one reason why I prefer to have one shop do all the modifications on my car, as it prevents more variables being added to the equation such as having multiple hands touching it. Didn't Albert initially have these mods installed at TTMotorsports? How did you or RPI come into the picture?
Albert, don't worry about this.... I'm sure we'll eventually figure it out. How did the dyno testing go today?
#44
Results were not good today?!!! Gotta be the headers aren't producing the said 40hp or so oe tune only and kleemen tune and header produced about the same
#45
All the mods (other than airbox mod done by TTM) were done at RPM North.
The car configuration was: K2 (K1+Kleemann headers), stock air boxes (dodger63 let me borrow his set), charcoals delete, K&N filters.
We did 5th and 4th gear runs, 4th gear runs produced better results, but eventually 5th and 4th gear pulls produced around 395RWHP SAE. We did about 6 pulls altogether.
So the verdict is: Kleemann headers made no measurable power gain on W212 and on one occasion actually showed a power loss (~10-15hp) based on a previous dyno. Updating the ECU from OEtune to Kleemann made no difference at all, changing out modded airboxes to stock did not yeld any power gains either.
All in all, disappointing and confusing. I am thinking about going back to stock at this point. All the time and money spent for nothing.
#46
FWIW, I didn't have a good experience with a K1 tune and was about 20whp less than a few other folks that had the K1. To prove the point on the track that was indicated on the dyno, I ran a 12.55 stock vs 12.45 w/K1, both w/ DRs. So I think a good dyno can be a good predictor of track times. What u can't duplicate on the dyno though is airflow and some tunes seem to work better at the track.
#47
Yep, results were disappointing. The most we made on the dynojet at NRG racing is 395 SAE corrected. I will be posting dyno graphs shortly.
Im sorry it didnt work out Albert.
RPM is gonna give you a refund and get you back to your stock exhaust though so get the OE file back on and go from there.
#48
#49
Albert, this may sound crazy but why not go with long-tubes? With a good set of long-tube headers and a tune, you should see 40 to 50 rwhp. The car will breathe better in high-speed runs and probably so will you
#50
