Does anyone know the advantage and disadvantage of new p30/31 rotor
Does anyone know the advantage anf disadvantage of the new design comparing with old p30 two piece rotor?
It seems no weight reducing(13.7kg/30.2 lb) v.s. old p30 rotor.
Does anyone know the price for it in US? As far as I know, the old p30 rotor is USD 1000/ piece.
Thanks for help in advance!
http://www.brembo.com/US/Cars/Dual-Cast/
Personally, if I were going to upgrade rotors I would go with the Evosport two piece rotors. They are lighter than either of the OEM two piece rotors. Also, they appear to be manufactured by the same people who built my two piece UUC rotors for my previous generation CTS-V. Here is a link for reference to the rotors I had on the V. They are strikingly similar to the rotors Evosport offers.
http://www.uucmotorwerks.com/CTS-V_f...ors/index.html
The funny thing is that while both my previous V rotors and the C63 rotors are nearly the exact same size, I only paid about $800 for the V/UUC front rotor set.
But if I have any further questions, where/who I can ask help from? For example, I don't quite understand how the new design can achieve the same level of "floating effect" of old two-piece-rotor? Is the cast iron "harder" than aluminium so the deformation of aluminium becomes the buffer?
Several issues need to be clarified here.
1. Since the hat is actually "cast around" the inward pointing stubs of the rotor, the connecting surfaces of both part are stuck/bound together tightly, right!
2. When the the rotor heats up and expands, the inward stubs should expand toward to center of hat. Am I right? PLS see the attached PDF file.
3. Since aluminum is softer than cast iron, the deformation on the hat will be more as the floating effect provider. Am I correct?
Add another picture for closer look of this new design.
2. The inward stubs would expand toward the middle, but the rotor, a ring, would expand at a higher rate(it is larger, so it will have more thermal expansion). When a ring under goes thermal expansion, both the inner and outer radii increase. The net affect will be that the stubs will move away from the hat, because the inner radius expands at a greater rate than the stubs. I could not get the file to open for some reason.
3. Yes the deformation of the hat should provide some floating effect.
I would like to make a note that I am note claiming that these work better than a standard two piece floating rotor. I am claiming that they work similarly.
Does someone want to talk to UUC about this?
Nothing EVER was developed by UUC for evosport.
UUC copied many of our designs for many products! So much so, one owner even tracked down and visited one of our manufacturing facilities once and asked for them to just make our products with their name (many years ago). This has been WELL discussed on many BMW boards and email lists by the way.
UUC products are not sold or even installed in our shop (even if you bring it in). Too many issues and problems and UUC ownership ALWAYS blames the install. lol
This is very serious what you wrote, please get the facts straight on this. I could not be insulted more!
thanks
brad
I would never compromise on brakes, wheels or tires to safe a few dollars.
thanks
brad
Just to be clear, I am in no way advocating for UUC. Also, I believe the rotors offered by Evosport are the best available for the C63. I also believe they are the same exact rotors I had on my CTS-V. I just want to know where they really come from.
Like most all businesses, we outsource much of our work. We have a full fabrication facility in house, however, for production items, they are sourced out to production houses. One such house is where UUC arrived and asked the owner to take our BMW pulleys and put their name and sell them to him.
As far as the rotors, we do the process in house along with our manufacturer. We examine the vehicle and the available disc options. This is limited by fitment with stock calipers. We then select and machine the rotors and hats and assemble with the highest quality fasteners.
The raw discs that others use, including UUC, may be from the same maker, however, the complete product is not, that I know for certain.
thanks
brad
