C63 AMG (W204) 2008 - 2015
For our cars, besides aesthetics, is there a benefit to wider tires on stock wheels?
Old Jan 15, 2011 | 01:34 PM
Pertplus's Avatar
Hyperion's Candy-Coated 4 x 4
Im getting my KW V3s this week and wondering if the car will drive better with tire dimensions other than the stock ones (235-40 and 255-35), or if getting wider tires will improve the overall drive comfort of the car (as opposed to just looking better parked). I know there are threads on how wide you can go, but Im curious (as a layman) if I should get different tires now I will [soon] have coilovers and a drop. Thanks
Plus
Old Jan 15, 2011 | 02:09 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
I recommend you start your car, turn off your traction control, put your tranny into sport mode then floor your gas pedal. If you don't spin your tires, then your stock 255 tires are fine. :p lol 255 is waaayyyy too small for the amount of torque that our engine produces. 275 should have been the minimum size for the rear tires.
Old Jan 15, 2011 | 02:15 PM
Militia's Avatar
C63
Wider tires = more contract with road = better grip.
My setup, like many others:
245/40/18 | 265/35-18
The handling definitely improved, but I don't think I'll be going any wider (at least not for performance reasons).
Old Jan 16, 2011 | 01:00 AM
mthis's Avatar
Anything W/4Wheels
what i runs for max grip is
235/40/18 Nitto NT05 $320
285/35/18 Nitto 555R DR's $490
thats what i do my daily driving on and it dont get any beter then that.
if you not a big fan of DR's then this is your next best set up
235/40/18 NT05 $320
275/35/18 NT05 $430
does are your best bet.
Old Jan 16, 2011 | 02:07 AM
DD GT3 RD's Avatar
'11 C63 w/ P31
What size are the stock wheels? assuming not so wide if they only put on 255...if you put to wide of a tire on a rim it will affect the handling negatively
Old Jan 16, 2011 | 09:05 AM
hhughes1's Avatar
2013 Chevy 427 Torch Red
Stock wheels are 18x8 front & 18x9 rear. Most tire manufacturers list 9" as the minimum wheel width for 275 tires. By far the most popular set up seems to be 265/245 which is what I run. My track wheels are half an inch wider and I have R888's in 275 mounted which fill the wheel well to the limit.
Old Jan 16, 2011 | 11:43 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
+1
Old Jan 16, 2011 | 11:55 AM
bli8's Avatar
C63 Seal Gray
I recently put on the Hankook EVO v12's in 245/265 and not only they fill the wheel wells perfectly, they also ride much much smoother and quieter than the stock rubber. While they are also stickier they give up a little steering feel and crispness in turn-in which I'm willing to trade for a DD. I'd say the C63 is now has the perfect blend of ride, handling, and grip for me.
Old Jan 16, 2011 | 12:12 PM
Chocofishez's Avatar
2014 E63 S
Any comments on 275 vs 265?
is the grip noticeably better?
Old Jan 16, 2011 | 04:59 PM
andy_c63's Avatar
2009 C63 AMG
What about 245/265 RE-11 or PS2? I am looking for better grip, but at the same time don't want to sacrifice cornering stability.
Old Jan 16, 2011 | 06:49 PM
andy_c63's Avatar
2009 C63 AMG
Wider tires are going to mess up the speedo quite a bit
Attached Thumbnails For our cars, besides aesthetics, is there a benefit to wider tires on stock wheels?-untitled.jpg
Old Jan 16, 2011 | 07:06 PM
I am Jeff's Avatar
It doesnt' mess it up anymore than how the BMW speedos come outta wack from the factory.
Old Jan 16, 2011 | 09:46 PM
OrientBlue3's Avatar
ED1 e63S
I'd also like to hear comments on 265 vs. 275. I'm about to order tires and want to make sure I'm getting the best setup.
Old Jan 16, 2011 | 09:57 PM
hhughes1's Avatar
Miles will accumulate slower as well
Old Jan 17, 2011 | 12:49 AM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Switching from 2065 tyres on rear to 275 made a world of difference to keeping traction in my car. prior to that even with 265 vs stock tyres of 255 i would struggle sometimes, particulalrly in wet conditions.
I think i have 285s Pirelli Corsas on back of my Black Series and they struggle sometimes, that thing is a beast !
