Evosport intake manifold spacer installed :PICS:
After removing the manifold we discarded to old gasket and put in the spacers along with the new gaskets. so its basically gasket+spacer+gasket, all of the parts were applied with a layer of sealant so I don't run into and leaks.
Here are some pics.
I doubt ill see any hp gains but I would imagine it would give out more efficient power becuase of the decreased temps.
OE should be able to tell you.
There are two tabs on the bottom. After you pop those out the rear airbox comes right up.
other companys call them thermalnators
When I did some research , other manufacturer were saying, reduced in
IAT will gain 3 degree timing resulting in HP gain .
What do you think ?
Also How do you remove the intake manifold? I think my car needs to have the
intake gasket checked.
