C63 AMG (W204) 2008 - 2015
Just bought used C63 have some questions...
Old Feb 4, 2011 | 01:29 PM
melmanc55's Avatar
C63 AMG
Hey guys, just bought a used C63 in great shape with only 13k miles. Several issues that i was needing help with. The car does have the p30 pkg on it. Everything is going great. I just have 2 minor issues.
1. Making a hard turn in reverse is producing a popping noise like i have a flat. like it is rubbing he interior fender wall. Anyone else experience this?
2. I am hearing a VERY light noise at slow speeds. almost like a wheel bearing is out. Call my service guy at mercedes and he told me a wheels might be slightly bent. Any of you have this problem? The thing is there is absolutly NO vibration in the steering wheel at any speed.
Thanks for any help.
Old Feb 4, 2011 | 01:42 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Sorry, I have only had my C63 since July and haven't experienced any of those symptoms.
Old Feb 4, 2011 | 01:43 PM
eagle_lex's Avatar
2012 E350 4matic
issue with #1 is PROBABLY what a few of us have noticed. IF you have summer tires on the front.... you are probably experiencing the front tires freezing and slipping when turned. i assume you are having cold weather in texas due to this crazy storm. the problem with summer only tires are the freeze and handle like they are solid plastic. when you turn they loose grip and basically hop or slide some which produces this odd sound.
i cant help you on #2. i doubt your wheels are bent however. take her in.
Old Feb 4, 2011 | 02:46 PM
ELO168's Avatar
C63, C280, 2500HD, IS300
I have the same issue's on the front tires
Only when is cold, after a few mins they are fine
Don't have the noise problem
Old Feb 4, 2011 | 02:58 PM
eagle_lex's Avatar
2012 E350 4matic
im moving to ulta performance ALL SEASONS on the front when they die. i just drive in cold weather 5 months out of the year and i dont really need all the grip that the Pzeros provide. you guys might want to consider doing the same. i dont see how the summer only tires can be safe if we are running them in freezing weather.
Old Feb 4, 2011 | 03:16 PM
MiamiAMG's Avatar
C63
I've had mine since October & haven't had either of those two issues. Take it to the dealer!
Old Feb 4, 2011 | 03:34 PM
pdjafari's Avatar
10 C63
I had similar issues w/ my OEM Continental 5SP or whatever but the tread was low/worn. Once I switched to Michelin Pilots problem went away.
Old Feb 4, 2011 | 04:48 PM
Hans Delbruck's Avatar
What I like!
+1 Tire noise can sound like worn wheel bearings at low speeds. (wum wum wum) What kind of tires do you have on the rear?
Welcome to the C63 forum!
Old Feb 4, 2011 | 05:39 PM
melmanc55's Avatar
C63 AMG
They are PZeros all the way around. Tread life looks pretty good....
Old Feb 4, 2011 | 10:11 PM
c63canada's Avatar
c63 amg
+1 some tires especially wide low profile can mimick quite well a bearing problem. had that on two other cars in the past.
Old Feb 4, 2011 | 10:17 PM
c63canada's Avatar
c63 amg
what does the tire tread look like?
Old Feb 4, 2011 | 11:16 PM
melmanc55's Avatar
C63 AMG
The tread actually looks pretty brother. Tires look fairly new.....
Old Feb 4, 2011 | 11:33 PM
c63canada's Avatar
c63 amg
is the noise coming from one corner or side in particular. If so, if you have a jack and the means to do so you could try changing your potentially offending wheel left to right. not front to back because the wheels are different.
If the noise switches side then you know the bearing is ok and it is most likely the thread of the tire that is worn unevenly.
Old Feb 5, 2011 | 08:21 AM
melmanc55's Avatar
C63 AMG
Thanks brother!
Can tell. I'll give a try.
Old Feb 7, 2011 | 01:56 PM
pdjafari's Avatar
10 C63
I spoke too soon, it looks my michelin pilots make a similar noise. Almost a clunk when I initially put the car in reverse from a cold start. It used to occur when I'd cut the wheel and reverse it happened yesterday just in Reverse...
weather is cold however...
