C63 AMG (W204) 2008 - 2015
want to take my car to the drag strip
Old Oct 22, 2011 | 11:46 AM
bluejae's Avatar
'10 C63
Originally Posted by PetroC63
I went to the Atco last night and the track prep was terrible. Couldn't hook up even with drag radials. Decided on my last run to put traction control in sport mode and managed an 11.70 @ 122.56 with a mediocre 1.837 60'
Made a total of 4 runs:
Run 1: 12.25 @ 119+ (1.988 60') Traction OFF
Run 2: 11.90 @ 120+ (1.918 60') Traction OFF
Run 3: 11.84 @ 121+ (1.914 60') Traction OFF
Run 4: 11.70 @ 122+ (1.837 60') Sport mode
The car was getting stronger with more runs coupled with cooler weather.
damn... can't wait to try again...
but now i need to shop for tires... decisions decisions... 95% of the time i'll be on the street daily driving... but i want something stickier than my pilot sport a/s plus so if when i do go to the track, i can be ready for some runs
Old Oct 22, 2011 | 12:37 PM
PetroC63's Avatar
2012 CTS-V
Nitto NT-05 are very good tires. Average in the rain but on dry pavement
they are excellent.
Old Oct 22, 2011 | 01:58 PM
bluejae's Avatar
'10 C63
they are excellent.
my michelins have a mileage warranty and if i get credit for it, then i can only apply the credit towards michelin or bfg tires... so if possible, i'd like to stick to them to save some dough.
Old Oct 22, 2011 | 02:58 PM
bluejae's Avatar
'10 C63
i'm thinking about trying the michelin pilot super sport
Old Oct 22, 2011 | 03:41 PM
bluejae's Avatar
'10 C63
what's the right way to stop or slow down during a burn out?
i held the brake with my left foot then stepped on the gas to about 4000rpm and a little higher after being into it for a second or so... then i eased off the brake and i started slowly going forward while tires were still spinning... at this point i wasn't sure what i was supposed to do... the first few times i let off the brake and slowly eased off the gas but the car started moving forward too much and i didn't want to keep going passed the staging line...
some of the other times i started the same way but i guess i burned out a bit longer and my car started to point a little to the left and started going forward... so i just left off the gas completely and it kind of jerked forward a little bit and i was able to straighten up...
each time i was able to stop the car before the staging line... is it worse for the tires in general when doing a burn out if you abruptly stop? or should you let your car roll forward and let the tires spin down on it's own?
Old Oct 22, 2011 | 05:08 PM
PetroC63's Avatar
2012 CTS-V
Normally, I roll through the water and stop just after the water box. Have the car in M mode, start my burnout exactly as you did(left foot brake, right foot gas) and full throttle the pedal anywhere between 5 to 10 seconds. After I see a good amount of tire smoke I release the brake and let the car roll forward as the wheels are spinning. Switch to S mode, click the left paddle and try to shallow stage the car.
Old Oct 22, 2011 | 06:16 PM
  #32
bluejae's Avatar
'10 C63
So after you release the brakes, what are you doing with the gas?
And you said you floor it? Is it ok to bump off the limiter like that?
And also is it ok to do burn outs in this manner? I've read that it isn't that great for the car but I don't see another way to do a burn out. And I'm assuming everyone else does it the same way.
Old Oct 22, 2011 | 11:29 PM
  #33
C63newdude's Avatar
C63 AMG
what do you have done to your C63 bluejae? you are virtually in the 11's. All you need is more passes and better tires.
Old Oct 23, 2011 | 12:26 PM
  #34
bluejae's Avatar
'10 C63
mbh catless headers, eurocharged v3 tune, row airboxes, bmc filters
Old Oct 24, 2011 | 02:21 PM
  #35
PetroC63's Avatar
2012 CTS-V
I continue to press the gas pedal and on occasion I hit the rev limiter.
No damage is done if you hit the limiter, it's there as a safety.
A burnout is not good for the tires, brakes and it will also build excess heat in the transmission.
Normally this is how a brunout is done unless you install a line lock.
Old Oct 24, 2011 | 02:26 PM
  #36
bluejae's Avatar
'10 C63
from your previous post, you said you full throttle the pedal for your burn out... doesn't this mean you're definitely hitting the rev limiter a lot?
so what you do is left foot brake, right foot full throttle (pedal to the floor)... spin for 5-10 seconds looking for smoke. then release the brake with your right foot still on the gas at full throttle. then your car starts moving forward and then what? do you ease off the throttle as you notice your car starting to go forward quickly? or do you let off the throttle completely to keep your car going way too far.
Old Oct 24, 2011 | 03:08 PM
  #37
Even Money's Avatar
'15 VW GTI
If you're going to make 1/4 mile passes a habit, get a line lock. Call ACGSD. It really makes things easy, and saves your rear brakes.
Old Oct 24, 2011 | 03:09 PM
  #38
PetroC63's Avatar
2012 CTS-V
It's very difficult to hit the rev limiter during a burnout when both the brake pedal and gas pedal are depressed. The only time the rev limiter comes into play is when releasing the brake(no more resistance) and keeping the gas pedal down.
I try to ease off the throttle as it starts moving forward but occasionaly I get overzealous and hit the limiter.
This is me doing a burnout, it might explain it better.
http://www.youtube.com/watch?v=QTopAn9Ew74
Old Oct 24, 2011 | 03:28 PM
  #39
Even Money's Avatar
'15 VW GTI
The first time with the line lock, it accel'd so quickly in first that I banged off the limiter before I could shift into second...it'll come real quick, espcially with headers and no brake resistance.
Old Oct 24, 2011 | 04:18 PM
  #40
bluejae's Avatar
'10 C63
i don't know how many times is considered habit... but i would think i would only go to the track about 2 times a year... and i would only want to go if i got some different tires i wanted to test or another mod... but i don't see another big mod in my future except for tires.
Old Nov 7, 2011 | 11:02 PM
  #41
bluejae's Avatar
'10 C63
planning to go back to the strip this saturday with some new michelin pilot super sports... should have them put on by thursday or friday...
going to try some runs with traction control in sport mode as petro suggested...
Old Nov 8, 2011 | 12:29 PM
  #42
PetroC63's Avatar
2012 CTS-V
Cool. Let us know how you do.
Old Nov 10, 2011 | 05:53 PM
  #43
bluejae's Avatar
'10 C63
i got the tires installed yesterday morning... they feel pretty good so far...
do you have to break in the tires before going to a drag strip?
any new tips or suggestions now that i got new rubber? although they're not DRs
Old Nov 11, 2011 | 12:48 PM
  #44
PetroC63's Avatar
2012 CTS-V
Not really. Drive the car hard on the way to the track so the ECU can adapt to your driving and try sport mode as I suggested if wheel spin becomes an issue.
Old Nov 11, 2011 | 12:51 PM
  #45
bluejae's Avatar
'10 C63
isn't there a point when traction is in sport mode and the tires spin too much and the traction control kicks in?
i'm assuming i'll have to try a few runs differently... like just flooring it at the light, or starting from 1000rpm or higher... or if too much wheel spin, try to ease into it a little bit
Old Nov 11, 2011 | 02:53 PM
  #46
PetroC63's Avatar
2012 CTS-V
Yes, traction control will interfere in sport mode but it's not as delicate as ESP ON. If you ease into the throttle as your accelerating traction control
may not kick in. It takes practice.
Old Nov 12, 2011 | 10:36 AM
  #47
bluejae's Avatar
'10 C63
what's the benefit of increasing the tire pressure in the front so much?
Old Nov 12, 2011 | 04:57 PM
  #48
DuaneC63's Avatar
AMG GLC63. Audi R8
New tires need to be scuffed up a bit before they achieve maximum traction.
Old Nov 12, 2011 | 05:17 PM
  #49
bluejae's Avatar
'10 C63
i'll be sure to do a little burn out each run
Old Nov 14, 2011 | 12:58 PM
  #50
bluejae's Avatar
'10 C63
so i wasn't able to go on saturday night like i had planned... i didn't realize that track i went to closed early on saturdays...
the next day was import face off in dallas... i went with my gf and they also did test and tune runs in between, i was only able to make 3 runs... but the time slips were a little disappointing... i was running 12.2 and 12.3... but the weather was quite warm too...
when i check the DA today, it showed as 2389 compared to the 960ish the first time i went last month... i didn't realize it made that big of a difference...
here are my times in order... my best time on the slips was my first run
12.242 @ 116.32 DA corrected 11.899 @ 119.757
12.392 @ 116.66 DA corrected 12.044 @ 120.107
12.266 @ 117.55 DA corrected 11.922 @ 121.023
if i went by DA corrected, i ran a personal best... but it looks so much better on paper damn it
