Smoke???
not firing on all cylinders, almost like an old car with distributor issues. Not sure how this is normal.
I'm assuming you know your car and know what's normal engine vibration.
If it's as bad as you describe, there may be something wrong.
Did any lights come on on the dash?
Sounds like possibly bad gas?
Maybe they've starting to water the stuff down now that it's gettin close to $4
GL, keep us posted
If your car is running rough, not firing on all cylinders and has white smoke pouring from the exhaust there is a problem!!!
It turned out that one (or more) of the gasoline injectors mal functioned causing excess gasoline to enter the cylinder chambers and thus producing the white smoke and mis firing. I had them replaced and the car ran fine again.
The tech couldn't exactly explain how this could happen but mentioned that poor quality gasoline might have damaged the injectors.
In any case be careful. My tech found a lot of un burned fuel in my exhaust which according to him could've caused a fire.
I strongly suggest having your car transported directly to the dealer.
Best
Ken
