C63 AMG (W204) 2008 - 2015
for 6.3 AMG: k&N, BMC, or PiperCross
Old 04-18-2011, 07:01 AM
Nimir Qatar's Avatar
2011 Mercedes Benz SLS AMG
Which is the best air filter out of those three that any of you have used and tested. Which one gives more horsepower? or are they all somewhat the same? What gains did any of you see on the dyno?. I
Old 04-18-2011, 11:18 AM
Former Vendor of MBWorld
TTMotorsports's Avatar
Whatever we're tuning!
K&N or BMC! FTMFW!!
Stay away from Pipercross!
Old 04-18-2011, 11:58 AM
audifreak's Avatar
c63
any particular reason to stay away from pipercross?
Old 04-18-2011, 12:01 PM
Even Money's Avatar
'15 VW GTI
I can personally verify that. When I took my pipercross filters out they each had tears on the rubber seals. Plus, they just didn't flow as much as air as even the stock paper filters. Switched to BMC...
Old 04-18-2011, 12:40 PM
MiamiAMG's Avatar
C63
Do you notice any difference with the BMC filters from stock? Thx
Old 04-18-2011, 01:31 PM
Even Money's Avatar
'15 VW GTI
I haven't had the stock filters in for some time, so can't really recall. I did notice an immediate difference in sound on the intake when I first fired it up with the BMCs. I'm hoping to get back on the dyno relatively soon, so maybe have some more info...Everyone I talked to about the BMCs swears by 'em, so go for it.
Old 04-18-2011, 02:34 PM
MiamiAMG's Avatar
C63
Cool, good to know. Thanks.
Old 04-18-2011, 03:35 PM
AMS Performance's Avatar
AMG
AFE Pro Dry S is also a fantastic solution and it is the #1 filter we recommend to all our customers. They flow just as well as other aftermarket filter but are 100% oil-free and do not damage MAS / HFM air sensors at all. They also clean with simple soap & water wash and are very affordable (usually $125-150 per pair). They will dyno roughly the same as other aftermarket high flow filters but without any of the problems that oil based filters create.
http://afepower.com/shop/details_new...V8&&brandID=59
L8brker (04-15-2017)
Old 04-18-2011, 06:30 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
You may want to check this out before trying BMC
https://mbworld.org/forums/sl55-amg-...bmcs-pics.html
Old 04-18-2011, 07:09 PM
Even Money's Avatar
'15 VW GTI
That's kind of what I had with my pipercross filters. The BMC fit perfectly on the air boxes, so above described issue shouldn't be a problem....but anyone can have problems...
Old 04-18-2011, 07:23 PM
GHAZAN's Avatar
MBUSA
paper filters FTW
Old 04-18-2011, 07:44 PM
boschk's Avatar
2006 CLS500 - Iridium Silver w/ AMG Sportline
I've run K&N's for years w/o issue. But, I read the instructions about cleaning and oiling the filter. I blame the problems with oiled media on the monkey applying too much oil and installing too wet, not the product itself. It works fine if used properly.
But, I'll consider the AFE's b/c they sound good and involve less work.
Old 04-18-2011, 07:46 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Stay away from any oil based filters. They will enventually foul your maf.
Old 04-18-2011, 08:13 PM
BEWJR's Avatar
2009 C63
TypePrice Choose one... Pro 5 RPro Dry S
Constructed with 100% polyurethane on all four sides, this high flow, oiled OE replacement performance filter
Old 04-18-2011, 09:28 PM
SonnyakaPig's Avatar
MB
I've run BMC's for thousands of miles and I've checked the MAF's frequently and I've seen no oil residue at all.
I recently picked up some stock paper filters made by Mann (they cost like $16-$17) and although they are a little more quiet than BMC's they function great.
I'll try the AFE drys sometime.
Old 04-18-2011, 09:31 PM
boschk's Avatar
At least 7 years of use with K&N on 3 different cars and many, many miles. No MAF foul. Why am I the exception?
Old 04-19-2011, 02:08 AM
Ok, I currently have Pipercross filters set up for an SL 63. So it wouuld be better to switch to BMC or K&N?
Old 04-19-2011, 03:30 AM
itsLoonie's Avatar
2012 E350 RWD
Only Pro 5 R is oil based. The Pro Dry S isn't. Hover your mouse over the emblems on the site like the one you quoted and you'll get a brief description. Or you can choose the type of filter first and it'll have different descriptions for both.
Old 04-19-2011, 03:32 AM
MB_Forever's Avatar
The filters in those pictures initially fit perfectly as well, but after a few miles of spirited driving, the filters seem to detach and bend out of shape. I'm hoping it's an isolated incident but who knows
Old 04-19-2011, 10:52 AM
That is an install issue. You have to torque the air box bolts in a systematic way so you don't pinch the filter on one end which is what the SL65 owner did.
I thought Andy would actually know how to install air filters!
K&N oil ruining MAF's...............you are all clueless that beliive that!
Old 04-19-2011, 01:21 PM
AMG
Correct, they have both oil based and non oil based. As I recall, The pro dry has a much higher filtration rate at 99.6% where as convetional oil filters are typically only 98.2%. Stock papers are roughly 99.8%, but with charcoals its pretty much 100%.
The pro dry will protect you engine better as well so it really is the best of both worlds, all the pros of the oil based, but with superior filtration of the paper. The added benefit of not having to ever reoil then is yet another long term cost savings that nobody factors in when comparing oil vs Pro dry.
Hope that helps,
AMS
Old 04-19-2011, 09:40 PM
SoCalCLK's Avatar
2017 W205 C43 AMG
You're not the only one. I ran K&N's on my 2002 CLK430 for 55K miles, no MAF issues.
I've ran K&Ns on my current CLK55 AMG for 50K+ miles, no issues. Breathes much better on the fwys. Those 5.4L engines need to breathe!
Old 04-20-2011, 04:59 PM
AMG Powerrr's Avatar
1999 Coupé Fiat 1.8 16v
I've got a Pipercross on my Coupe Fiat, and it roars like hell! My friends driving Alfa Romeo with an BMC, which isn't half as much as loud as mine Pipercross... A K&N is a silent whistler when you compare it to a Pipercross or a BMC
Old 07-11-2012, 09:16 PM
C6G
C6G's Avatar
C63
Stay away from Pipercross! Mine were very poorly manufactured and are coming apart after my first cleaning. Going to probably just go back to good ole papers
Old 08-01-2013, 12:30 AM
SoCalCLK's Avatar
2017 W205 C43 AMG
What about the AEM DryFlow filters? They have a bunch of applications for Mercedes. No oil, no MAF worries, right?
Quick Reply: for 6.3 AMG: k&N, BMC, or PiperCross
