C63 AMG (W204) 2008 - 2015
How long have you left your CEL on?
Old Jun 9, 2011 | 01:45 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Exclamation How long have you left your CEL on?
Ive taken my car in twice to get the CEL turned off but it just comes on again the next day the car doesnt do anything that would lead me to believe there is something detrimental going on that would cause future problems....so,
I was wondering if I should worry about it?
What is the longest that any of you have left it on?
And do any of you just not worry about it at all? If so, how long have you had the CEL on and has anything bad come of it?
My mods are listed below and the last time I took it in to the shop they said it had something to do with the cats but they found no problems with it. They just deleted the code.
Old Jun 9, 2011 | 01:49 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
What is causing the issue in the first place?
Old Jun 9, 2011 | 01:53 PM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Dude, your car is new....wTf???
Old Jun 9, 2011 | 02:00 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
We should have a sticky of all the CEL occurrences. It seems these cars constantly throw codes.
Ive had one on for close to a month for the Purge Valve issue. Went to the dealer 3 times for it, and just kept lighting back up.
Now i randomly get one for Lean Bank 1. what is your code?
Old Jun 9, 2011 | 03:05 PM
CELLryuu's Avatar
C63 AMG Coupe P31
apparently it has something to do with the cat? thats what the shop said.
ya, but i modded it so i have no one to blame but myself at the moment tell i can figure out why the hell it keeps coming back on
I agree with the CEL sticky because I did a search several times before I posted and came up with a little help but not much.
as for the code -- im going to have to ask the next time i take it in but like i said above, the shop said it had something to do with my new cats?
BTW -- my CEL has been on for about 2 months now :O
Old Jun 9, 2011 | 07:25 PM
_AMG_'s Avatar
C63
Could be your 02 sensors.
Old Jun 9, 2011 | 07:57 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Possible but the codes indicate that its the cat which may be covered under the Kleemann warranty. Ill just have to take it back to the shop and find out. Thing is, I dont drive the car much and the shop is an hour away.
I was just wondering how many people said "f|_|ck it" and just got fed up and drove with the CEL on anyway lol.
Old Jun 9, 2011 | 08:01 PM
Sonny@Marranos's Avatar
Former Vendor of MBWorld
E55,S500,C200 KOMP,SV300 ,LANDCRUISER SAHARA
Take it back to your tuner and get it adjusted thru the ecu,its easily
regards sonny
Old Jun 10, 2011 | 03:14 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Ok, I took it back to the shop and the code read P0430
He said that we will keep working on the problem of a CEL but that nothing was going on that was harmful to the engine.
What is P0430 in your guy's opinions? (P0430 Catalyst System Efficiency Below Threshold (Bank 2)) Which side is bank 2?
Old Jun 10, 2011 | 03:17 PM
PetroC63's Avatar
2012 CTS-V
1) The catalytic converter is no longer functioning properly
2) An oxygen sensor is not reading (functioning) properly
3) There is an exhaust leak
First, inspect for exhaust leaks.
Next step is to measure the voltage at the oxygen sensor on Bank 2. In fact, it would be a good idea to test each oxygen O2 sensor while you're at it.
Old Jun 10, 2011 | 03:27 PM
jakio's Avatar
C63 2011
It is the cat,same for me can't erase the code,erase and come back again.
Old Jun 10, 2011 | 03:52 PM
CELLryuu's Avatar
C63 AMG Coupe P31
Well I just did some phoning around and Ive found that the most likely problem is a sensitivity issue in the tune that needs a little refining. There is apparently nothing wrong with the car. The ECU is just reading the chemical levels (through the 02 senser) in the exhaust as being environmentally unfriendly.
Im just going to have to be annoyed by that yellow light for a bit longer until we can find a tuning solution for it. Hopefully
Old Jun 10, 2011 | 04:39 PM
dodger63's Avatar
2013 f250 6.7 diesel
22,000 miles with cel on
Old Jun 10, 2011 | 07:12 PM
Send me your ecu and ill fix the issue : )
Regards sonny
Old Jun 11, 2011 | 12:31 AM
JCH's Avatar
JCH
2009 C63
3 days so far. Came on a month or so ago and went off after 3 days. A few months prior to that it came on and dealer replaced the purge valve. If it persists I'll take it to the dealer. Runs just fine. I'm not worried about it. Seems to be a fairly common occurrence with these cars.
Old Jun 11, 2011 | 02:22 AM
_AMG_'s Avatar
C63
I would contact Kleeman, and talk to them about replacing your HFC's under warranty, That would be the best option imo.
Old Jun 11, 2011 | 02:54 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Always have it checked but unless it flashing or the car is running funny, it's just usually some smog bs.
Old Jun 11, 2011 | 09:46 AM
CELLryuu's Avatar
C63 AMG Coupe P31
Already contacted them and they were very informative. They explained the entire situation to me, as they have come across this situation several times.
I ended up having it checked again (as I stated in an above post) and you are exactly right, (in short) it all comes down to some smog bs
Old Jun 11, 2011 | 09:54 AM
mthis's Avatar
Anything W/4Wheels
lmao thats why your car is the Q/F C63 NA bc of the CEL
Old Jun 12, 2011 | 10:12 PM
JCH's Avatar
JCH
2009 C63
Sure enough, my CEL went off yesterday on it's own after another 3 day appearance. This is the second time in about 3 months. Seems to occur after filling the tank, but then again I am often filling the tank so go figure. I did notice that the oil level was a bit low and added 1/2 qt, but assume that was unrelated to the CEL. Guess this is just part of the experience of lving with the "Beast".
Old Jun 13, 2011 | 11:32 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Well.. I have never left a CEL on.. but I live in a state where you have to get emissions checked every 2 years, and it's an auto failure if there is a CEL.
Then there is VA, where you have to get a yearly inspection, again, auto failure if any lights are on (not just CEL).
I guess if you don't have inspections, I would not worry about it if you can get in writing that it won't affect the engine in any way..
