C63 AMG (W204) 2008 - 2015
Sun Roof wont close without holding down button, but it will open with one touch...
Old Sep 27, 2011 | 09:51 PM
Pertplus's Avatar
Hyperion's Candy-Coated 4 x 4
Just got my car back from stereo shop about 45 mins ago and I know my battery was disconnected for part of the install, and in the past sometimes my windows didnt go up "automatically" but would go down (or vice versa). Is there a way to cycle through this for the sun roof, or do I just have to drive my car around for a while for it to "remember" to work?
Old Sep 27, 2011 | 10:14 PM
C63newdude's Avatar
C63 AMG
Talk to the service advisor, I had a similar issue with the driver side window and my service advisor "walked me " through step by step over the phone and I was good to go in like 30 seconds.
Old Sep 27, 2011 | 10:37 PM
SMP's Avatar
SMP
CLK63 Black Series
If I recall correctly, all you have to do is hold the switch, open and close the roof 3 times and the one touch feature is operative again.
Old Sep 27, 2011 | 10:39 PM
_AMG_'s Avatar
C63
You put in subs in what?
Old Sep 28, 2011 | 06:27 AM
Naif647's Avatar
'09 C63
Close the window, and the keep holding the switch down for a while, and the open it and do it again, for about 3 times, and it show work properly again..
(I'm not saying it has to be 3 times but it worked for me whenever it happened to my windows or sunroof).
Old Sep 28, 2011 | 09:12 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Just read your owner's manual page 88, Resetting instructions for the sunroof.
Old Sep 28, 2011 | 09:15 AM
mthis's Avatar
Anything W/4Wheels
LMAO and i been driving with this issue for 7 months now.
tnx guys
Old Sep 28, 2011 | 09:22 AM
Yuille36's Avatar
tnx guys
Is your warranty expired? I can't understand why, you have been living with this issue for so long. Take it to Mercedes and have them fix it.
Old Sep 28, 2011 | 10:01 AM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Yeah, this is something you can do yourself. Try the reset function. With the sunroof closed, pull downward on the switch (i.e. as if you are trying to close it from the up-tilted position) and hold it in that position for about 20 seconds. Eventually, the sunroof will tilt open fully and then you can release the switch. Now close it and it should be reset. Pretty much the same proceduyre for the windows. I believe this is in the owners manual.
-Walter
Old Sep 28, 2011 | 10:06 AM
mthis's Avatar
Anything W/4Wheels
still have it just to lazy to go to dealer.
plus sunroof always stays closed in my car.
Old Sep 28, 2011 | 10:07 AM
mthis's Avatar
Anything W/4Wheels
-Walter
Tnx im going to try rite now.
Old Sep 28, 2011 | 10:11 AM
mthis's Avatar
Anything W/4Wheels
Not working for me.
Sunroof don't pop up
Old Sep 28, 2011 | 10:16 AM
Try this one.
1) Open or try to open your moonroof all the way. Once it is fully opened, push the moonroof button toward the rear passenger sit and hold it for a good 5 seconds then release.
2) Upon completion of step 1, close or try to close the moonroof all the way. Once the moonroof is fully closed, push the moonroof button toward the winshield and hold it for a good 5 seconds then release.
3) Upon completion of step 2, open or try to open the moonroof to the tilt up-ward position ( like a triangle /_ ). Once it is fully tilt, push the moonroof button up toward the sky and hold it for a good 5 seconds then release
For the windows:
from the driver side switch pod roll the window all the way down and keep button pressed for 5 seconds when the window is down. then roll the window all they way up and keep button pressed for 5 secs. the auto roll up/down should start working then
Old Sep 28, 2011 | 10:30 AM
mthis's Avatar
Anything W/4Wheels
Try this one.
For the windows:
still not working
uploading a video now to see if i did it rite
http://www.youtube.com/watch?v=-Jf8jD_WK7E
Old Sep 28, 2011 | 10:36 AM
still not working
Haha..That's all I got. It's in the manual. I sold my car, so I no longer have the manual to look at.
Old Sep 28, 2011 | 10:38 AM
Yuille36's Avatar
It cold be the fuse is blown for the sunroof. Have you check that yet?
Old Sep 28, 2011 | 11:06 AM
mthis's Avatar
Anything W/4Wheels
No that I haven't checked
Will do that tomorrow. Tnx
Old Sep 28, 2011 | 11:13 AM
mthis's Avatar
Anything W/4Wheels
Tnx for u help much appreciated
Old Sep 28, 2011 | 02:13 PM
Pertplus's Avatar
I think the issue I have is related to the motor for the sunroof, because when it goes back automatically, there are no issues. But when you try to "one touch" it so it moves forward, the above cabin lights flicker a little and the roof keeps hesitating when it closes; meaning that, it doesnt close smoothly, but kind of like the sound a roller coaster makes when it goes over the tracks on the start of its incline.
Old Sep 28, 2011 | 05:59 PM
Pertplus's Avatar
still not working
Same Exact sound as mine!!!!!!
Old Jun 7, 2012 | 12:33 PM
ggms16's Avatar
2009 C300 4Matic Sport
any solutions?
Happened to me as well.
Old Jun 7, 2012 | 02:47 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I have found a recent intermittent problem with mine as well. When I one-touch close it, it almost closes, then retracts. I think it's the rubber accordeon looking things that are jamming somehow. I'm not sure if this is the same problem you're having. The YT video was taken down.
Old Jun 7, 2012 | 10:55 PM
Pertplus's Avatar
Originally Posted by ggms16
any solutions?
Mercedes reset it for me. I don't remember exactly what they said but i think it was the module
Old Jun 8, 2012 | 06:13 AM
Harold1898's Avatar
2015 E400 Coupe
I ad this in my CLK it is one of 2 things. Either you have a build up of gunk on the tracks and TNT needs to be cleaned off or you need to reset it. In the CLK you opened it fully with your finger held on the switch,mthen you closed it fully with the finger on the switch. Then presto, it was reset. Might be different in C63 but doubt it.
