C63 AMG (W204) 2008 - 2015
Common Problems with the C63 AMG
Old May 26, 2012 | 02:40 PM
  #201
C63coupe2012's Avatar
E63 S 2014
Just got mine after it spent 4 days at the dealer to fix the rattle noises and so far so good. Will post if it comes back but the dealer did a great job, the mechanics basically unmounted the whole cluster, added grease and fabric to isolate the contact points. We will see how it goes!
Old May 26, 2012 | 05:04 PM
  #202
izzyAMG's Avatar
2019 GLC63, 2020 M2 Comp, 96 Miata M Edition & 19 Forester
It would be nice for you to share the report what they did so we can share it to the dealer when we take our cars if it applies to us.
Old May 27, 2012 | 08:33 PM
  #203
Gremlin9's Avatar
Porsche 911
Waiting for delivery is the biggest problem...
Old Oct 10, 2012 | 01:28 AM
  #204
MaroonC63's Avatar
2009 Barolo red C63 AMG (SOLD).13' P31 c63 coupe 2012 porsche panamera
The more you read about rattles, the more you'll notice it. Never noticed a rattle in my car till I read this thread. Thanks guys -___-
Old Oct 10, 2012 | 10:53 PM
  #205
RL1's Avatar
RL1
AMG C63 Affalterbach Edition
very easy solution...just drive exclusively in 1st and 2nd gear and keep the engine near the redline...you won't hear any rattles
RL
Old Oct 11, 2012 | 04:52 PM
  #206
bigsl550fan's Avatar
sl550
MB did a poor job with fit and finish with the interior. I've had rattles since day 1 with my 2012 C63 coupe with P31, had the dealer work on it 3 separate times and they claimed to resolve the issue and the noise came back the next day. Their excuse was that it has a hard suspension. If I pushed it further I would have a master mercedes tech work on it but I'm sure tearing apart the dash and rear brake light area will only create more rattles.
The main issues are the navigation screen area and the right rear speaker/3rd brake light area. It has annoyed me for months but I've tried to tune it out. As far as I know no fix is avail for these two problems only putting felt tape around the contact points.
Old Oct 12, 2012 | 01:58 PM
  #207
farhadahmad's Avatar
C63 Coupe Edition 1
it happens in all the coupe i believe. they fixed it 1 shot for me and it never came bacl. its the rear break light
Old Oct 12, 2012 | 02:00 PM
  #208
C63 Coupe Edition 1
Let everyone know i just came back from the AMG ACADEMY and theres going to be an update to are ecu for the LIMP MODE and over heating everyones having on the track!!! if u go on private lounge they talk about it
Old Oct 12, 2012 | 03:55 PM
  #209
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
key gets jammed when trying to remove it sometimes,and a slight squeak from the steering wheel once in a while. anyone encounter these issues?
Old Oct 12, 2012 | 05:00 PM
  #210
dacatz's Avatar
From: Richmond Hill - Markham area, Toronto, Canada
c63, prius
i think this one i have is gotta be a good one.....the trunk is out of align went i pick up my car on the first day....have to sent it back for re-align!
Old Dec 12, 2012 | 01:49 AM
  #211
-=Hot|Ice=-'s Avatar
Cars.
Friendly bump for an update from anyone.
Old Dec 12, 2012 | 02:26 AM
  #212
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
I get a lot of rattling from my rear sun shade. When it is in use, the noise is gone, when it folds away, it starts rattling. I hate that thing.
Old Dec 12, 2012 | 02:36 AM
  #213
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
My body shop guy said that's a trait about the sunshade, not MB specifically.
Old Dec 12, 2012 | 06:18 AM
  #214
USCGTO's Avatar
your mom
I don't even remember when was the last time I used the key in any of my Mercedes to start the car. My 2007 E550, 2009 Gl and the C63 all had keyless go.
Personally, I think I can't live without that.
Old Dec 12, 2012 | 11:39 AM
  #215
AMGangster's Avatar
2010 C63
Originally Posted by SonnyakaPig
My dealer just informed me that MB is no longer fitting the bill under warranty for the in-cabin filter changes. I think they charge a couple hundred bucks. Last year they were doing this for owners under warranty.
Do it yourself for $30 from Napa.
Old Dec 12, 2012 | 11:46 AM
  #216
Gremlin9's Avatar
Porsche 911
p*ssy juice stains on the passenger seat, whenever a girl sits in the car for the first few times, prolly from not being used to the torque
after a few times, it seems to stop being a problem as habituation occurs
Old Dec 12, 2012 | 11:50 AM
  #217
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Rough idle when I first got the car. Took her in a few days later, they checked and said that I must add fuel additive to the tank. Keep in mind that we run 95RON here and all other cars seem to run fine. My E60 M5 ran fine with this fuel.
Anyways, additive didn't solve the issue.
Took her in last week and they confirmed adjustment of cams. That seemed to have worked! It was all done elctronically.
Old Dec 19, 2012 | 03:20 AM
  #218
white1's Avatar
c63 2012
C63 AMG 2012
I received my c63 4 weeks ago all good apart for engine vibration at around 1400rpm to 1900rpm. Best detected by driving around 95 to 100kph on 7th gear and try to accelerate slowly, the vibration can be felt through the car. MB told me its normal due to their gearbox, but I just can’t understand car with high price tag having vibration. Has anyone had this issue?
Old Dec 19, 2012 | 03:25 AM
  #219
olszowa12's Avatar
'08 C63 Estate
Definitely not normal.
Tell the dealer to take it for a test drive.
Are You sure it's the engine, not the wheels?
Old Dec 19, 2012 | 03:39 AM
  #220
white1's Avatar
c63 2012
defiantly sure. it happens through out all gears. Harder to detect on lower gears as the engine revs up quicker. and normally if its from wells vibration will be constant. if cruising only no vibration only when you accelerate you can fill it and only at low revs. If driving in manual mode also can run in 6th gear at around 1400rpm approximately 85kph and accelerate slowly the vibration will be felt as well but not as much as on the 7th gear. If anyone with similar car can try this type of driving and see if they fill vibration will be appreciated. I have another appointment on 27th at MB and see if they can solve it.
Old Dec 19, 2012 | 11:02 AM
  #221
motoman's Avatar
C63AMG, NIssan NX2000, Pontiac Fiero GT
Bogus blabber from your dealer. Car is smooth as silk in all situations.
Proof-wife never complains and detects ANYTHING out of ordinary. You must pursue this with some dealer.
Old Dec 25, 2012 | 10:32 AM
  #222
white1's Avatar
c63 2012
Will be going back to dealer on 27th and will test 2 more cars to compare them will post result on Thursday
Old Dec 25, 2012 | 12:02 PM
  #223
motoman's Avatar
The plastic key has ears which get "dry" I put a VERY LIGHT film of silicone grease on about twice yearly. Don't get carried away-just a film. You can get this stuff at plumbers supply or use a VERY LIGHT film of brake caliper grease. DID I SAY VERY LIGHT FILM- oh yeah.
Old Dec 25, 2012 | 12:24 PM
  #224
motoman's Avatar
This sounds like an exhaust bracket/pipe touching or maybe a bad motor mount. Something loose?
Old Jan 17, 2013 | 02:15 PM
  #225
breakfast's Avatar
AMG
Ive never seen so much whining about interior rattles in my life.
sure its a 70k car but deal with it. Its not a rolls. Machines/cars make noises AND VIBRATE.
