INTERMITTENT CEL
Thanks.
http://buy1.snapon.com/catalog/item....re&dir=catalog
2 questions:
1. Could this be due to K&Ns with no charcoals?
2. Does the car run the same with CEL on? Doesn't seem to be in limp mode.
Thanks.
1. Possibly. Did your CEL pop up after installing the K&N's? Some other members have had the same issue after removing the charcoals and installing
aftermarket filters.
2. It should if you drive normally but the ECU may dump timing if it senses a lean condition.
Try putting the charcoals and stock filters back in, erase the codes and drive around to see if a CEL pops up again.
Mike
Bring your car to a shop that uses snap on computer
Some of the newer snap on computer can tell if your 02 sensor are good or bad.
