C63 AMG (W204) 2008 - 2015
2012 C63 Steering Wheel Fit 09 or 10
Old Feb 8, 2012 | 03:33 AM
r0me0x's Avatar
'10 C63
Hey Guys saw a few pretty sick 2012 C63 Steering Wheel Setups. Will they fit a 2009 or 2010 C63? The button format looks to be the same. Am wondering if it will be plug and play?
Old Feb 8, 2012 | 03:58 AM
TonCoronel's Avatar
Mercedes ML350, Mercedes C63 AMG
Yes its a plug and play BUT if you only replace the steering wheel and ofcourse the airbag the buttons wont light up on the steering wheel. You also need to replace the column to the 2012 one (A212 900 7702) Yes its an E-Class number but its the corect one.
Edit: It seems that now it is possible to reprogram the original column in stead of buying the 2012 one, see topic https://mbworld.org/forums/c-class-w...ml#post5004170
I did it and my daughter seems to like the wheel
Old Feb 8, 2012 | 07:27 AM
PoliticalIcon's Avatar
C63 coupe
I did it and my daughter seems to like the wheel[[/COLOR]
Looks good!! Really freshens up the interior!!
Old Feb 8, 2012 | 11:11 AM
cptdaz's Avatar
home the point
Thanks for the information. I'm actually trying to do the same upgrade. Unfortunately the website that has part for sale don't use part code system. What year E Class? Will any E Class work or just column from specific models?
Is part #1 what I need?
Which column do I need on this site?
https://www.getmercedesparts.com/par...iagram=5719310
Old Feb 8, 2012 | 12:07 PM
TonCoronel's Avatar
The only that will work is the 2012 one, that column is both used in the W212 (e-class) and W204 (c-class).
I am afraid I cant help you with that website, I am only familiar with the codes Mercedes uses. You have a lot of different 2012 columns(With or without cruise control, memory function etc) and to be able to identify the correct one you really need the MB part number.
Again there is a possibility that you dont need the new column but can reprogram the current one although there is not much know about that at the moment.
Old Feb 8, 2012 | 12:54 PM
r0me0x's Avatar
'10 C63
Thanks for the reply. Has anyone figured out how to make the buttons illuminate as well on the steering wheel? Makes no sense it'd be plug and play but the buttons dont light up?
Old Feb 8, 2012 | 01:04 PM
TonCoronel's Avatar
Well I thought the same so I asked around to see if the cable harness maybe needed an adjustment, maybe the ground and/or + for the lighting only changed on the new column but I didnt find the answer to that.
So to summarize you have 3 options:
- Install the 2012 E/C Class Colum - 100% confirmed working
- Have the old column reprogrammed for the new steering wheel - Some say it worked but didnt tell who/what/where etc to do it
- Change the cable harness of the old column if you can find out the old and new electric schema of the column - unconfirmed, just a thought
Old Feb 8, 2012 | 01:45 PM
cptdaz's Avatar
home the point
Thanks for the information. Do you mind telling us where you got your w212 column and how much it was?
Old Feb 8, 2012 | 02:05 PM
TonCoronel's Avatar
I got mine from the dealer, I live in the Netherlands (next to Germany) and for parts you can best go to the dealer here and try to get a good discount (I get 15-20% discount).
I believe I payed around 250 euro for it
Old Aug 4, 2012 | 07:54 AM
clichere1's Avatar
W205 C63S E.1
TonCoronel ... after you upgrade to the new steering, the paddles were functioning normally? is this with the column or without?
I installed mine recently, I don't care everything is working well except for the buttons illumination and the paddles which the most important for me.
I hope anyone else could update us.
Old Aug 4, 2012 | 08:59 AM
islandboy518's Avatar
C63 amg
hi guys,
i want to know if its possible to have a 2008 c63 performance package with leather steering wheel?
your help is greatly appreciated.
Old Aug 6, 2012 | 04:34 AM
TonCoronel's Avatar
My paddles directly worked on the new steering wheel with both the old and the new column. The paddles do have their own connectors so maybe the person who installed in forgot to connect the paddles?
Old Aug 6, 2012 | 09:00 PM
clichere1's Avatar
W205 C63S E.1
That's weird , the dealership did the instilation.
I'll check it out tomorrow.
Old Aug 7, 2012 | 03:56 AM
clichere1's Avatar
W205 C63S E.1
I found in other forum that there's a coding update need to be installed to get it worked? is that true?
Old Aug 7, 2012 | 04:23 AM
TonCoronel's Avatar
Nope thats not true...
If your original steering wheel already had shifter paddles (and you have a C63 so yes it has) then you dont need a coding update to let the new wheels shifter paddles work.
If the original wheel did not have the shifter paddles like some/most of the lower speced C classes (C300/350?) then there is a coding update needed so the car understands it has shifter paddles installed.
On the forum someone said that you can have the old steering column get reprogrammed to make sure the lights on the steering wheel work but never told us what to recode, and this was only for the lights and not the paddles.
Old Oct 5, 2012 | 09:06 PM
clichere1's Avatar
W205 C63S E.1
An update regarding my paddle issue:
I went to DCT motorsports and Ivan gave me a big help and sort this issue out
While examining my paddles and the other working paddles that DCT motorsport have, we found that my paddles (in Carbon Fiber) have different part number than the working one. CF paddles were the type for 2008-2011 steering wheels, so it has different wire termination than the paddles (silver) for 2012 steering wheel. The paddles has two cables (yellow and black), and the difference between the two models was they were in opposite side.
So we flipped the termination (black to yellow, and yellow to black), and it worked perfectly (what it's in the photo is the right termination).
Long story short, if the paddles were from the older model (2008-2011) and will be connected to 2012 steering wheel, the termination of the paddles cable need to be changed/flipped.
Big thanx to Ivan from DCT motorsports for his talent and help.
Old Oct 15, 2013 | 10:11 PM
Brunotaxi7's Avatar
C250 CDi
Talking steering wheel shift W204 pre-facelift to the existing steering wheel W204 facelift!
good day
We here to get the lights to work! ... exchanged the motherboard of the old airbag to the steering wheel again! is easy, with a little effort, the best would be to send the photos, explaining step by step how to not have much experience posting in the forum, I'll try to post some photos here, or you can e-mail!?
BrunoTaxi7
Attached Thumbnails 2012 C63 Steering Wheel Fit 09 or 10-placa-volante-2012.jpg   2012 C63 Steering Wheel Fit 09 or 10-img_2296.jpg   2012 C63 Steering Wheel Fit 09 or 10-img_2442.jpg   2012 C63 Steering Wheel Fit 09 or 10-w204-volante-avangarde-2012-j-montado.jpg
Old May 13, 2014 | 07:27 PM
aznmode's Avatar
2010 c300
Originally Posted by Brunotaxi7
good day
BrunoTaxi7
Sorry to bring up old thread and I don't have a c63 but a 2010 c300 and have updated the steering. I assume pre FL steering motherboards are identical to all pre FL w204 but I've noticed they are not the same as FL steering motherboard. Just not sure how you got it to swap.
Has anyone here done the motherboard swap?
Old May 13, 2014 | 10:25 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
I didn't do the motherboard swap. Just the steering column swap and it worked for the buttons to be lit.
https://mbworld.org/forums/c63-amg-w...ing-wheel.html
Old May 13, 2014 | 11:33 PM
aznmode's Avatar
2010 c300
Unfortunately I can't find a w212 column so I'm trying to figure out another way. Thanks for the reply though. At least I now have paddle shifters.
