Thinking about lowering my estate
I have no experience whatsoever about lowering vehicles. Even the terminology is (for now) quite unfamiliar to me. I suppose coilovers would be the way to go?
Now, to those of you who have lowered your cars:
a: how much does ride comfort suffer?
If yes to a, B: Does it have to suffer for 20mm or are there viable options?
c: Problems?
d: What setup do you recommend? I want to be able to adjust the suspension back to a good level for next winter.
Any other input is also welcome. Please bear with me, i'm really unfamiliar within this subject.
If you plan on staying with the stock wheels/tires than a drop shouldn't be a problem.
All kidding aside, many people have lowered without any rubbing. You just have to take the amount of drop, wheel offset and tire width into consideration.
Seems H&R are the way to go. Here in Finland we just have a vastly poorer aftermarket parts market compared to North America. Maybe just best to order the parts online and install them at an MB dealership. I once brought my M5 to a normal shop to install scoops. They forgot to put some part back so my car went into limp mode..i think it was an air hose or something like that. Like stated earlier, not an expert, i just love driving. Maybe i should study a bit...
http://www.hrsprings.com/scripts/app...ind3&MakeID=25
What do you guys think? Winter is coming so i would like the option to raise the car above current stock level but when spring comes lower it below. Is this possible?
Are You asking about KW HLS or H&R coilovers?
H&R can be adjusted from stock height to -4cm (as on my pic above).
