C63 AMG (W204) 2008 - 2015
Wheel offset: ET 45 Rear??
Old Mar 20, 2012 | 06:35 PM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Would a 19x9.5 with ET 45 work for the rear wheel?
Old Mar 20, 2012 | 06:49 PM
gthal's Avatar
2012 C63 coupe
A 265 rear tire on this will is 14mm pushed out from OEM. It should be OK if you aren't lowered. On my car with OEM wheels and 265 tires, I can tell you I don't have 14mm to the fender.
Old Mar 20, 2012 | 07:44 PM
RuckinAMG's Avatar
C63
My rears are 9.5 with a 50mm offset lowered on H&R. My rear rubs when I hit hard bumps. I'm going to switch my 275 to 265 this Friday.
Old Mar 20, 2012 | 08:00 PM
ET50 seems to be what everyone says. So ET45 would push the wheel out another 5mm right? My car is a non lowered P30. I was looking at some of these 19" AMG replicas and they are saying the 19x9.5 ET45 will fit the C63?
Old Mar 20, 2012 | 09:16 PM
RuckinAMG's Avatar
C63
On a non lowered car should be fine.
Old Mar 20, 2012 | 09:23 PM
_AMG_'s Avatar
C63
You should be fine depending on your tire choice.
I'm running 19x9 +45 in the rear and its close.
Old Mar 20, 2012 | 09:25 PM
Are you lowered and what size tire are you running?
I was looking at Conti DWS and Hankook V12s
Old Mar 20, 2012 | 09:29 PM
_AMG_'s Avatar
C63
Yes, im lowered and running 265 Michelin Super Sports. Those specific tires run wide and its close.
I was running 265 Hankook EVO V12's before the Michelins and had good clearance, no rubbing whatsoever.
Old Mar 20, 2012 | 09:33 PM
Im non lowered P30, so I might be lower then stock C63 my a small amount.
I was looking at the DWS tires as I was told they will last the longest.
Old Mar 21, 2012 | 12:37 AM
LAMB09's Avatar
2011 C63 AMG
I am i the process of ordering the SLS replicas from Power Wheel Pros. It is a 19x9.5 et45 rear but am having it machined to an et48 after posting on the forum and getting input about et45. Plan to run a 265 tire and keep the suspension stock, would like to run a 275 but not sure. Good luck and keep us posted
Old Mar 21, 2012 | 07:11 AM
bobbyzcar's Avatar
Do you have a pic or link to the SLS replica? I don't see it on their site.
Old Mar 21, 2012 | 08:19 PM
AMGTTV8's Avatar
2026 AMG GT63 Pro
I used to have 19's that ran a 45mm offset and they rubbed pretty frequently in the rear...marred the tires
Was running a 265 pirelli.
Old Mar 21, 2012 | 08:49 PM
Were you lowered?
