C63 AMG (W204) 2008 - 2015
Coolant usage-may be the "bad news"
Old May 4, 2012 | 02:39 PM
  #126
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by late_bloomer
Did Amg start replacing different head studs after unit 0060658? Anyone see old vs new parts? It seems it would be difficult to know for sure if newer models are affected.
Anyone with tunes/ aftermarket parts having dealership fight repairs while still in warranty?
Here’s a picture of the old head bolts and new head bolts. They are obviously different. The issues seem to be metallurgy of the old bolts which after many expansion and contraction cycles fail by snapping. MBZ is aware of the problem and is using the new head bolts in engines after 0060658. As the heads of the bolts are different you could pull a valve cover to confirm which bolts you have.
Old May 4, 2012 | 03:40 PM
  #127
bhamg's Avatar
C63 AMG
Originally Posted by c32AMG-DTM
splinter
ScottW911
Vic55
Rock
^^^All good guys who I'm sure can help you out. GL!
OK, PM with appropriate referenced threads has been sent to the mods above to ask for; a) merging of recent threads regarding coolant loss and head bolt failure, and b) pinning said thread on the C63 forum as a sticky. We shall see...
Old May 4, 2012 | 03:44 PM
  #128
DuaneC63's Avatar
AMG GLC63. Audi R8
Bhamg. Thanks for undertaking this. I have a sense we're in for a battle with MBZ.
Old May 4, 2012 | 04:10 PM
  #129
PaulWdz's Avatar
CLK63 Black Series
Originally Posted by DuaneC63
Here’s a picture of the old heal bolts and new head bolts. They are obviously different. The issues seem to be metallurgy of the old bolts which after many expansion and contraction cycles fail by snapping. MBZ is aware of the problem and is using the new head bolts in engines after 0060658. As the heads of the bolts are different you could pull a valve cover to confirm which bolts you have.
I assume the one on the left is the old design ?
Old May 4, 2012 | 06:17 PM
  #130
bhamg's Avatar
C63 AMG
I assume the bolt on the right is the old design as it is the used bolt.
Old May 5, 2012 | 12:37 PM
  #131
JohnnyUte's Avatar
C350 4matic coupe
One failed head bolt and another with corrosion, definitely sounds like a metallurgy issue. I'd love to swap them all out with ARP fasteners and be done, but I'm sure that'd void any warranty.
Old May 6, 2012 | 02:13 AM
  #132
DuaneC63's Avatar
AMG GLC63. Audi R8
That is my understanding also.
Old May 7, 2012 | 01:20 AM
  #133
Stanley Kao's Avatar
around what timeframe was engine 0060658 made? Anything after that is safe right?
Old May 7, 2012 | 01:54 AM
  #134
bhamg's Avatar
C63 AMG
IIRC someone posted that their car fell into the "old head bolt run" and it was a MY2010. I think they said that...
Old May 7, 2012 | 03:01 AM
  #135
DuaneC63's Avatar
AMG GLC63. Audi R8
Yes if falls in the MY2010 range.
Old May 7, 2012 | 05:38 PM
  #136
exdes's Avatar
2015 C300 4matic
When dealer replaced the intake manifold gaskets, someone mentioned that they replaced the bolts with newly designed ones. Are these head bolts? or some other bolts?
Old May 8, 2012 | 12:24 AM
  #137
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Would prior to MY2010 also be ok?
Old May 8, 2012 | 12:59 AM
  #138
Merc63's Avatar
C63 AMG
Probably torque to yield bolts on the intake manifold. Which can only be used once.. They use these on the tranny pan too, you have to buy new bolts when you flush it.
Old May 8, 2012 | 02:30 AM
  #139
DuaneC63's Avatar
AMG GLC63. Audi R8
This is correct. Any torque to yield bolts can only be used once. If you have a head bolt break they will replace all the head bolts with the new design head bolts.
Old May 8, 2012 | 09:37 AM
  #140
Mort's Avatar
No, all engines up to Engine #15698560060658 are at risk according to the information given in this thread.
Old May 8, 2012 | 11:42 AM
  #141
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
So are MY2011 and mY2012s safe?
Old May 8, 2012 | 05:17 PM
  #142
Sincity's Avatar
I believe so since the engine range cutoff is early/mid 2010.
Old May 9, 2012 | 04:23 PM
  #143
Was thinking of buying an used C63, thinking twice about that now. Is there some way to easily check if a 2010 C63 was built after MY2010? Man i feel bad for anyone trying to sell a c63 that's built prior to MY2010, their re-sale value probably just went down by at least 5000 dollars. I am hoping MB USA knows about this.
Old May 9, 2012 | 04:36 PM
  #144
C6G's Avatar
C6G
C63
Wow! Can't believe this, 22k now on mine no problems yet. Thinking I should run the **** out of it this summer and sell it before factory warranty is up. lol So much for keeping my beloved hand built motor for a long time.
Old May 10, 2012 | 01:09 AM
  #145
DuaneC63's Avatar
AMG GLC63. Audi R8
The sure way to check is the engine ID# which any dealer can give you if you have the VIN#.
Old May 10, 2012 | 11:22 AM
  #146
IslaDave's Avatar
2011 C63 AMG
I have a very early build 2011 P31 C63. I have asked my dealer to get my engine number for me. I will post it when I get it.
Old May 10, 2012 | 01:35 PM
  #147
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
My CDN 2010 is affected and 10602 M156 engines built after mine.
Does anyone know if the engine code started at 569XX 60 000000?
Old May 10, 2012 | 07:38 PM
  #148
Pit-Pony's Avatar
2015 C63S E1 (sold 2012 C63 AMG Sedan (Premium & APX)) & 09 C300 Sport 4Matic
On the positive side, I doubt that every single engine below the target VIN will break. Only some will and I know we can't foretell which ones those will be.
I think the best option for those affected is to purchase extended warantee and/or ask MB if this will be covered post warantee period.
Old May 10, 2012 | 08:36 PM
  #149
morganb's Avatar
C63 AMG, C36 AMG, SL500
Update on my Car. MB says it not the head bolts. Requiring a full engine strip down to determine whats wrong. No help yet from MB Aus on the cost of this though it seems like some sort of catastrophic failure which I do not think should have occurred on a 3.5 year old 51K KM motor serviced on the dot by MB themselves. The Service Tech says he has not seen a similar type of failure! Will know more on Monday.
Old May 11, 2012 | 06:05 PM
  #150
bhamg's Avatar
C63 AMG
Best of luck with the repair morganb. My M5 required an engine replacement just out of warranty also. Different problem, similar situation, it required a complete teardown, a new long block and numerous other parts as well. In my case the resolution of the contributions to the cost of the repair took two minutes to resolve - we decided on 1/3 factory, 1/3 dealer and 1/3 mine. Although that ended up costing me into five figures I thought it to be eminently fair and was pleased all parties agreed to the settlement so quickly....having no hard feelings about it on anyone's part was good thing!
