Dumb question-CPO:What is the real benefit?
Can you explain me what is the difference between a CPO and a normal used car? Since I'm still on the look for a used C63, and since I saw several C63's already, I would like to know better the benefit of a CPO program. Does a CPO really make sense even if the car will be more expensive if I compare it against a non-CPO C63 (used)? The MB website does not help me at all... I need a feedback from actual C63 owners.
15 Point Undercarriage & Drivetrain Inspection
Drive shaft flex discs, couplings, and center support brg(s)
Exhaust system/connections/supports
Parking brake and cables
Brake lines
Tire wear (including spare); depth = 50% above TWI
Brake rotors/pads (minimum of 50% pad material)
Shock absorber/damper struts
Suspension inspection
Self-leveling suspension, if applicable
Front/rear axle rubber mounts/bushings
Steering play
Tighten steering gear bolts
Cigarette lighter(s)
Front axle ball joints
Steering shock
11 Point General Inspection
No Identifiable Structural Damage Verification
Mileage/history verification and CARFAX report
All recall and/or other campaigns performed
Current maintenance, Warranty Booklet, and Owner's Manual
All spare keys (including wheel locks if installed)
Radio theft deterrent CODE cards presents
SRS date label (Check date — 15-year validity)
Roadside Assistance Program label affixed
Inspection label affixed
Flash-up the newest software if available for all telematics components , if applicable
Perform short test. Diagnose any stored DTCs and repair as necessary
11 Point Engine Compartment Inspection
Engine oil
Transmission oil
Rear axle oil
Transfer case and front axle oils, if applicable
Engine compartment/antifreeze protection
Power steering fluid
Brake fluid and clutch fluid
Windshield washer fluid(s)
Level control oil, ADS, ASD, 4MATIC fluid, if applicable
Battery condition/midtronics test
Throttle linkages, if applicable
17 Point Engine Component Inspection
All emission control systems in place and functional
Fuel filter and pre-filter
Spark plugs
Perform compression test (vehicles over 60,000 miles)
Fuel injection system, verify lamda reading (gas), if applicable
Injection system including routing of ignition wires (gas), if applicable
Pre-glow system function - visual (diesel), if applicable
Injection pump timing, if applicable
Vacuum pump, leak evidence of oil in vacuum line (diesel), if applicable
Boost pressure (diesel)
Air cleaner/filter
V belts, poly-V-belt
Engine mounts
Heating and ventilation dust filter, if applicable
Active charcoal filter/pre-filter, if applicable
Recirculating air filter, if applicable
A/C refrigerant charge system
25 Point Chassis and Body Inspection
Body structure inspection
Glass, lamp frames, and lenses
Central lock system function test (interior/exterior)
Mechanical locking with all keys at all points
Alarm system function, if applicable
Power window operation from all points (including lock-out)
Interior trim; inspect dash, door panels, seat covers, wood, etc.
First aid kit
Orthopedic seats — function check with engine running, if applicable
Seat belts — condition/operation
Front seat belt height adjustment
Front seat center armrest and hinge, if applicable
Front sun visor/vanity mirror
Rear vanity mirror, if applicable
Roll bar pop-up headrest, if applicable
Parktronic, if applicable
Soft top and seals — condition and operation, if applicable
Hard top, remove/install top wrenches, seals, if applicable
Door/trunk lid closing assist , if applicable
Remote trunk release, if applicable
Station wagon tailgate closing assist, if applicable
Rear-facing third seat — station wagon, if applicable
Door/trunk/tailgate seals; inspect drains
Sliding roof function, drains, and headliner
Inspect glass roof for scratches/corrective action, if applicable
3 Point Post-Road Test Inspection
Fluid leaks visible inspection
Automatic climate control — residual heating
All fluid levels (underhood)
33 Point Electrical System Inspection
Fuses (condition/proper rating)
MIL check, indicators in instrument cluster
Dash instruments, clock, illumination, and dimmer control
Exterior rearview mirrors
Exterior mirror fold back, if applicable
Interior rearview mirror, if applicable
Automatic dimming rearview mirror function, if applicable
Radio (satellite radio, if any) and stereo speaker function
Cassette player, clean tone head CD drive, Navi processor, CD lens cleaner
Automatic antenna, clean mast
CD changer/player, if applicable
Cellular telephone, if applicable
Rocker switches, function, tactile feel, and LED/Illumination
Steering column adjustment and memory, if applicable
Seat adjustments and memory, if applicable
Cooled seats, if applicable
Heated seats/ventilated, if applicable
Front seat belt extenders — coupe and cabriolet, if applicable
Front seat backrest latch/release — coupe and cabriolet, if applicable
Front seat backrest latch/release chime/warning lamp — coupe and cabriolet , if applicable
Rear window defroster — check current draw with DMM, if applicable
Rear head restraint retraction, if applicable
Rear window sunshade
Horn (including fanfare)
Headlamp low/high beam and all exterior lights
Tele Aid — listen for pre-recorded ATX message, if applicable
Voice Control system — basic functionality, if applicable
Rear seat backrest latch/warning lamp, if applicable
Panorama roof function and rollo shades
Interior and entry lighting
Windshield wiper/washer, system/rear window wiper/washer
Windshield wiper inserts, headlamp cleaning system
33 Point Appearance Inspection
Engine wash
Trunk mat
Trunk paint
Spare tire, tools & jack
Moisture and odor
Vacuum and shampoo
Interior floor mats
Interior carpet
Interior upholstery
Interior headliner and door panels
Buttons, knobs, and vents, instrument panel
Glass and mirrors
Interior wood and chrome trim
Interior vacuum and shampoo
Interior screws
Ashtrays
De-grease door jamb, hinges, kickpanels, and visors
Interior moisture and odor
Exterior dings, dents, and scratches
Examine paint
Examine and clean chrome
Glass and mirror housing
Grille
Lamp lenses
Badges
Exterior trim and moldings
Wipers
Bumpers
Exterior door edges and frames
Wash and wax
Wheels (scuffs and scratches)
Wheels (cuts and gouges)
Wheels (wash and polish)
/mercedes
cpo
cpo-multipoint-inspection
[ { "vehicleClass" : "SL" , "vehicleBodyStyle" : "RDS" } ]
3709414864MERCEDES-BENZ
CERTIFIED PRE-OWNED
Overview
Pre-Owned Offers
Inventory Search
Certification Process
Warranty Information
Service and Support
Model Overview
Request a Quote
Download Overview Brochure
Download CPO Accessories Brochure
Trade in Estimator
Brake lines
Steering play
Steering shock
Engine oil
Transmission oil
Rear axle oil
Spark plugs
Air cleaner/filter
Engine mounts
First aid kit
Engine wash
Trunk mat
Trunk paint
Moisture and odor
Vacuum and shampoo
Interior floor mats
Interior carpet
Interior upholstery
Glass and mirrors
Interior screws
Ashtrays
Examine paint
Grille
Lamp lenses
Badges
Wipers
Bumpers
Wash and wax
/mercedes
cpo
CERTIFIED PRE-OWNED
Overview
Pre-Owned Offers
Inventory Search
Service and Support
Model Overview
Request a Quote
Trade in Estimator
with a CPO car from mercedes, you know that the inspection has been accurately done and that when you invest in this considerable amount of pocket change, the car will function as it should. IMO it is definitely worth going for
CPO cars automatically get the additional 1 year/100,000 mile. After that, you qualify to buy the MB Pre Owned Extended Warranty, which adds an additional 1 year/120,000 mile, or 2 year/135,000 mile.
If you buy a non CPO car, you can't even buy any extended warranty from MB. Only current original owners can purchase the extended warranty, and that's during the warranty period with a CPO like inspection by the dealer.
If you don't care about warranty or go 3rd party, then yes, CPO isn't worth it at all.
So a CPO car will give you a min of 6 years after first registration. imo its a good deal regardless if you think you know cars or not. A transmission breaking down after 1 year of use isn't something you can predict or see. It's happened to me before and that 10k fix was fully paid for by MB canada.
2. While the paint on my front bumper looked fine, it began to come off in patches. It's clear that whoever did the work didn't prep the bumper right before painting it. Should CPO have caught this? Maybe, maybe not.
It's not a bad thing and it has value... to a point.
came accross this and remembered this thread. might be worth a read.
CPO is a good thing but if its possible to buy from an owner who has the max Extended Limited Warranty and it transfers to you, thats excellent also.
Non CPO from a non-MB dealer might leave you without good exteneded warranty options.
I had a CPO C32 which had numerous faults in it. It should have never been CPO. It was in a front end collision, had new bioxenon headlights which werent an option on the car, and a NAV unit from Mbenz NL. I doubt they did anything to certify it. The only plus was the extra year on the warranty.
Back then MB had free maintenance but it did not carry over to the extra year. That's when i learned to do it myself.
One of the major benefis of the CPO warranty, however, is that it is independently administered by the dealership, so if you have a problem with the car (which is covered), there is no need to call for approval from the outside warranty provider when you bring it in to have the repairs made.
Still, it is a very good idea to ask for a detailed explanation of what is and isn't covered under ANY warranty program.
When a 4 year old car has 50k miles, it'll have better chances to sell with a higher resale value if its factory covered for another couple years and anopther 50k miles or more.
Its pretty simple.
