C63 AMG (W204) 2008 - 2015
M156 head bolt problems
Old May 4, 2013 | 11:33 AM
  #326
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by Karl901
So you saying, if your car was Mfg after May 2010, the head bolts are OK?
Only known for sure way for MY 2010 is to check the engine number.
Regards,
Joe
Old May 4, 2013 | 11:35 AM
  #327
Valvestud's Avatar
Originally Posted by Sincity
I would venture to say yes because it also affected C63 production up to 2010.5.
Head bolt issue is not relevant to models, only the engine serial number range, and applies to M156 engines across the MB model range.
Regards,
Joe
Old May 5, 2013 | 01:08 AM
  #328
Sincity's Avatar
^ I was trying to say that.
Old May 5, 2013 | 02:57 PM
  #329
otakki's Avatar
FF. W212 E63 M156 non-pano 18" P2 ParkT NightV (gone but will be missed).
Originally Posted by PurpleHeartAMG
I have a question about E63 headbolts and didn't really find anything there. My friend wants to know if the 2010 E63 has the same headbolt issue as the C63's do.
Help is much appreciated gents
The answer is yes. I have that MY E63 and someone ran my engine number in the STAR system and found it's in the affected batch. Thus it depends on when the engine is built.
That's why I have the extended warranty for 7yr/135K and I'll trade in before it expires.
Old May 6, 2013 | 01:06 PM
  #330
noXor's Avatar
2011 C63 AMG
So to confirm, any MY2011 should be fine?
Old May 6, 2013 | 01:52 PM
  #331
Valvestud's Avatar
That's correct.
Regards,
Joe
Old May 9, 2013 | 11:00 PM
  #332
carboxy's Avatar
07' 911 Turbo, 09 ML63
My
Engine no.: 156980 60 044563
Am I affected by head bolt if so what are the warning signs?
Old May 9, 2013 | 11:02 PM
  #333
GrnLantern's Avatar
SLS
Originally Posted by carboxy
My
Low coolant warning.
Old May 9, 2013 | 11:05 PM
  #334
carboxy's Avatar
I just purchased ml63 few weeks ago and put almost 2k miles on it. So far no coolant level yet
I did see a check engine oil light but when u checked a few hours later, I see oil is between min and max more like towards 3/4. Manual says that ok
Should I check coolant level daily or weekly?
Thank ya
Old May 10, 2013 | 08:01 AM
  #335
Valvestud's Avatar
My
Yes, you are affected.
Old May 10, 2013 | 08:26 AM
  #336
schmick325's Avatar
RR Evoque Dynamic, Benz Valente (work hack)
Thank ya
The car tells you if its low. No need to check it on a consistant basis.
I have had my car for 3 years, engine number 156980 60 003674, yeah a real early one! Have had low coolant message come up once so I topped it off.
This was 2 years ago.
Theres no need to panic - just be aware.
if you top it off and it comes back, don't drive it.
Old May 10, 2013 | 06:32 PM
  #337
solekeeper's Avatar
A V8
where is engine number located? and how do i research to know if it is affected?
Old May 10, 2013 | 11:00 PM
  #338
carboxy's Avatar
I ask some members to do vin decode n it will show engine number
Old May 10, 2013 | 11:01 PM
  #339
carboxy's Avatar
Do I buy only mb coolant? Also does your car get cold then sometimes gets warm then cold later?
Thank you for advice
Old May 10, 2013 | 11:07 PM
  #340
bhamg's Avatar
C63 AMG
Use the MB coolant. Some types of coolant stocked at the automotive stores are not compatible with the OE coolant.
Old May 10, 2013 | 11:38 PM
  #341
Valvestud's Avatar
Reply with your VIN and I will look it up.
Regards,
Joe
Old May 11, 2013 | 01:45 AM
  #342
Merc63's Avatar
C63 AMG
Originally Posted by drawde
$5k including parts and labor? I remember reading somewhere that's roughly the price including install for the weistec head bolts? correct me if i'm wrong. I was thinking about getting it done kind of preemptively but if it's gonna be the same price to fix it later (or $0 if nothing happens) i might as well wait? thoughts?
my car has 70k miles on it, i have extended warranty until 110k miles but through a 3rd party (fidelity). Anyone hear of 3rd party warranties footing the bill for this? Been skipping through and so far I've only seen MB warranty.
5k to put studs in?? Nice, I'll do it! Mbworld discount too!
Old May 12, 2013 | 07:40 AM
  #343
carboxy's Avatar
I'm curios too! I have mercury will they do it or it has to fail or early warning signs such as coolant?
If so how do I tell em
Old May 12, 2013 | 08:00 AM
  #344
aussie e55's Avatar
2009 C 63
Smile
hi what ia the start & finish numbers on engines that could have head bolt problems thanks
Old May 12, 2013 | 08:43 AM
  #345
Valvestud's Avatar
Any engine number below 569xx 60 060658 is in the group. It's unclear how deep into 2010 group goes, but all 2009 and earlier are affected.
Regards,
Joe
Old May 12, 2013 | 08:52 AM
  #346
aussie e55's Avatar
2009 C 63
thanks joe
Old May 12, 2013 | 11:21 AM
  #347
Critter's Avatar
07 E63 + 07 CLK63CAB
Hello fellow owners,
Not to tread on anybodies parade but is there someone out there that could explain why there seems to be a lot of failures of the head bolts in the C63 platform but few on the E63 Platform. I have read that the possible diff is the fact that owners of the E usually or a higher percentage take their cars to the dealer?
What I would really like to know is that when the original head bolts were designed and resourced are there actual batch numbers for the bolts and were they supplied from the same supplier, were there different suppliers? I find it hard to believe that Merc purchased a whole train car full of bolts to be used in all future engines but you never know. Thanks in advance for any info dealing with my queries.
Old May 12, 2013 | 11:55 AM
  #348
Valvestud's Avatar
The car model nor bolt batch is relevant. The M156 went into multiple car models and until they made the switch, all previous engines are suspect. If they could have traced to a particular lot, then they would have also identified a particular lot or lots of engines. The issue isn't lot related, it's design related.
If there are more failures in the C, it's more likely due to numbers sold versus other models.
Regards,
Joe
Old May 12, 2013 | 01:00 PM
  #349
Critter's Avatar
Joe,
Thanks for the quick reply
Having worked in the steel industry for 3 decades plus, I do understand your statement of it being a design issue, but the metalurgical components, the so called cake mix aspect of the first bolt out of the die in 05 or 06 could not and would not be the same as the bolts coming out of the die two years later. When I see bolts that have a washer area that is not properly centered this is not design but poor quality control.
Thank You again for your input Joe
Are there stats showing failure rates according to year of manufactor? 07- 10
Has anyone found out if the bolts were in fact supplied from one supplier? This I realize would probably be answered from internal knowledge of AMG sourcing.
Anyone out there?
Old May 12, 2013 | 11:08 PM
  #350
Merc63's Avatar
C63 AMG
That's easy.
The C63 demographic is younger, more guys online. Plus there is WAY more C63s than E63s.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
