C63 AMG (W204) 2008 - 2015
Removing Wheels on my 2012 C63?
Old 05-12-2012 | 11:30 PM
Pickles's Avatar
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Question Removing Wheels on my 2012 C63?
I like to keep my brake rotors & inside wheel/hubs etc clean, so thought I might, at some stage, remove the wheels to do some cleaning....I'll probably use the supplied car jack to enable this.
I was just wondering, that with tyre sensors, are there any things I should look out for when taking the wheels off, & then putting them back on.
Anyone had any issues with the standard jack/jacking points?
Cheers, Pickles.
Old 05-13-2012 | 01:46 AM
LAMB09's Avatar
2011 C63 AMG
I am curious about needing a torque wrench to properly torque the lugs? Not sure if this is required but see them doing this when I get new tires on my other cars.
Old 05-13-2012 | 02:00 AM
Merc63's Avatar
C63 AMG
Lugs should always be torqued to spec.
Old 05-13-2012 | 03:06 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Anyone know the specs?
Old 05-13-2012 | 03:14 AM
Merc63's Avatar
C63 AMG
96ftlbs
Old 05-13-2012 | 04:46 AM
Harold1898's Avatar
2015 E400 Coupe
Cheers, Pickles.
Hey Pickles, now that is ****! LOL
I watched them take my wheel off yesterday at bob Janes and there was nothing out of the ordinary. Floor jack, bolts off, wheel off. Putting it back on there was no torque wrench, the guy just did it up till he felt it was right.
Old 05-13-2012 | 05:20 AM
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
If I was paying somebody to do maintenance on my vehicle (wheel instalation) then I want them to do it by the book (torque values), wheel over torque could result with cracks around the bolt hole or thread damage.
Old 05-13-2012 | 05:53 AM
Originally Posted by Merc63
96ftlbs
Thanks!
Old 05-13-2012 | 07:39 AM
WagsC63's Avatar
Merc C63 wagon (hopefully!)
Should ideally use torque wrench to do the final tightening of the nuts.
Rattle guns can damage studs easily eg strip threads.
They also inevitably overtighten them so much that you might not even be able to loosen them if you had to do an emergency tyre change with the supplied tyre wrench...ask me how I know this!
Old 05-13-2012 | 08:41 AM
MB280S's Avatar
C63
I have a torque wrench set at 130Nm which is recommended torque.
Old 05-13-2012 | 01:00 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
The TPMS units are located inside the tires (it's an extension of the valve stem that nests just inside the rim), so no need to worry about that. On my old ('10) C63, the only issue I kind of worried about was bonking the calipers as I moved wheels on & off.
Old 05-13-2012 | 02:50 PM
ArrogantZ's Avatar
'12 C63,
You can take the wheel off with no problems always torque the wheel.
As far as the sensors put the wheel back on the corner it came off of or you will have to reset the TPMS for instance left rear has to be put back on the left rear if you put it on the right rear it will still say it is the left rear
Old 05-13-2012 | 05:30 PM
I'm pretty sure MB TPMS does not have to be reprogrammed if you change the location of the wheels (proximity sensors).
Old 05-13-2012 | 07:03 PM
Mort's Avatar
Since this car uses lug bolts and not lug nuts on studs get one of these handy tools for removal and remounting your wheels. It makes the job so much easier and user friendly. It screws in like a stud to guide the wheel off and back on again and makes lining up the lug holes a piece of cake. I got mine from Reverse Logic and Fred is a great guy to deal with.
http://www.reverselogic.us/ReverseLo...ited/Home.html
Old 05-13-2012 | 07:37 PM
Pickles's Avatar
Thank you all for your replies, particularly "Justthebest" as I didn't know where the sensors are, & didn't want to "disturb", or damage them.
So, you've all found the factory jack to be OK?
Cheers, Pickles.
Old 05-13-2012 | 10:11 PM
Cheers, Pickles.
No problem Pickles - and re: the factory jack, I've only had to use it once, and it worked to get the flat off & the spare on. That said, if you're going to be doing relatively frequent wheel swaps, then I would recommend investing in a legitimate floor jack. It will save time & effort, and they don't really cost all that much.
Old 05-13-2012 | 11:08 PM
If you're in a pinch, how would you get the lugs off? I've found the MB supplied wrench basically useless, as WagsC63 pointed out. I would prefer not to have to carry a breaker bar in the trunk.
Old 05-14-2012 | 02:12 AM
Pickles's Avatar
Question
I like the look of them.
Did you order the ones shown on the list.."W204 C Class 2008=Present M14X1.5?...ie are they the right ones for the C63
I reckon the S/S items would be worth the extra would they not?
Cheers, Pickles.
Old 05-14-2012 | 03:22 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Don't use the mickey mouse stock jack. Get a floor jack and the proper jack pads. http://www.reverselogic.us/ReverseLo...Jack_Pads.html
After you've driven it a few hundred miles check the torque on the lugs.
Old 05-14-2012 | 04:00 AM
bhamg's Avatar
C63 AMG
My dealer in SoCal cracked (and replaced) the side skirts because there was insufficient clearance for the slightly lower P30 suspension on some of their lifts. They were alway embarrassed when I would show up for a service app't with four of Fred's jack pads. I always carry one in the car for a tire changing emergency.
Old 05-14-2012 | 04:56 AM
Pickles's Avatar
Question
Mort...another question.
I've also looked at the jack pads you mentioned, from the same supplier. So these sit on top of my trolley jack & enable me to lift via the factory jack points, because this device slots into the factory jack location? Is that correct? For your C63 did you order part no, "W204Plus"?
Thanks again, Pickles.
Old 05-14-2012 | 05:08 AM
bhamg's Avatar
C63 AMG
Not Mort but the rectangular part of the jack pad snaps into the matching "receptacle" on the underbody of the car and is held there. The circular disc portion of the jack pad is a good fit for most jacks.
Old 05-14-2012 | 08:10 AM
callmiro's Avatar
2016 C63 S
Just wondering why you would need this? The wheels are hub centric and sit on the hub and can be rotated on the hub to get the desired lug location
Old 05-14-2012 | 08:27 AM
Infamouz's Avatar
C204, W209, W164
I thought that too... being hub centric, it's already the most user friendly way of removing and installing.
Nothing hard about rotating the wheel around until you see all the holes match up. Even for a mere $10, I don't see the point.
Old 05-14-2012 | 09:18 AM
PatSC23's Avatar
2009 C63
I would suggest getting a hydraulic floor jack - the OEM jack is pretty flimsy. I personally dont trust it as my car has moved while on it, even on a flat surface.
Quick Reply: Removing Wheels on my 2012 C63?
