C63 AMG (W204) 2008 - 2015
Rear tire replacement question
Old Jun 10, 2012 | 01:10 AM
bmoney12's Avatar
2019 Audi TT RS, 2020 BMW X3M Competition
My rear tires are about done and was wondering what I should replace them with? I have the 19" AMG V-Spoke rims...what's the widest I can run? Any recommendations would be much appreciated!
Old Jun 10, 2012 | 01:16 AM
_AMG_'s Avatar
C63
What kind of tire are you looking for? More grip? Long tread life? etc...
balthaser's Avatar
2009 C63 AMG
the non-official recommendation on this forum is 275 or 265 Michelin PSS
Lots of us have these tires
Old Jun 10, 2012 | 01:36 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
A width dimension of your rim would also be helpful.
Old Jun 10, 2012 | 01:47 AM
_AMG_'s Avatar
C63
The OEM 19's are 19x9.
Old Jun 10, 2012 | 01:54 AM
Didn't have them, so I didn't know.
OP, depends on the look you're trying to achieve, like how much of the sidewall is visible. So if you get 265 vs. 275, there maybe more or fewer options.
Old Jun 10, 2012 | 03:11 AM
_AMG_'s Avatar
C63
No worries.
Old Jun 10, 2012 | 06:23 AM
gthal's Avatar
2012 C63 coupe
I run 265 PSS on the rear and am very happy with the look and performance. Any wider would look too bulgy IMO and the sidewall would roll under load and make the car feel less responsive. IMO, if you run 275 or larger then you should have wider rims to better support the sidewall.
Old Jun 10, 2012 | 07:11 AM
_timothy's Avatar
c63
has anyone tried yokohama advan sport?
Old Jun 10, 2012 | 07:15 AM
hyperion667's Avatar
2012 CLS63
sounds like a 255 or smaller??
Old Jun 10, 2012 | 09:23 AM
norb's Avatar
2009 C63 AMG
Michelin PSS for me! Love them.
Old Jun 10, 2012 | 02:35 PM
bmoney12's Avatar
Thanks sounds like Michelin PSS is the way to go! Is anyone running different brands for front and rear? The Conti sportcontact 3's on the front have 80% life left. Should I get 4 new PSS or wait and replace the fronts when needed?
Old Jun 10, 2012 | 04:36 PM
CELLryuu's Avatar
C63 AMG Coupe P31
i know this has been covered a hundred times but are people that are running 275s on the stock 18x9 wheels ok with them?
Old Jun 10, 2012 | 10:34 PM
Here's what I got when I picked up this car from Vivid
Front: 20x8.5 rims with Toyo T1R Proxes 235/30/20
Rear: 20x9.5 rims with Vredestein Ultrac Sessanta 285/25/20
I wore down my rear tires and was only going to get another set of Vreds until I needed to replace all four, then I'd get Michelins. But I found out too late that I had a gash in the sidewall of my front tire so I ended up going with the exact same setup again.
Old Jun 10, 2012 | 10:56 PM
cuchanonM's Avatar
bmw
Old Jun 10, 2012 | 11:00 PM
_AMG_'s Avatar
C63
Ya, 255's are the OE rear tire sizes.
You can fit up to 275's on a 9" wide wheel.
I swapped out all 4 tires so I can get the full PSS experience. lol
Its totally up to you though, if the Contis have 80% life I would just keep them on and replace the rears with the Super Sports.
Ive ran 3 sets of 275's on the OEM 18's. No problems at all.
Toyo T1R's run narrow so you are able to get away running the 255/285 combo. You would run into rubbing issues if you ran the same size Conti's or Michelin's (PS2/PSS).
Old Jun 12, 2012 | 02:27 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Just be aware that if you change the width and offset you're going to change the camber and toe. Since the C63 has no rear camber adjustment, you're stuck with what you end up with unless you want to spend a few bucks on additional suspension parts (dog bones, etc).
Old Jun 12, 2012 | 04:02 AM
Jmoley's Avatar
2011 e90 m3
245/35/19 fronts
275/30/19 rears
Michelin PSS from day one!!!! Told my dealer to sell me the car less the conti-shiznitz.....
Old Jun 12, 2012 | 08:40 AM
shades's Avatar
09 C63, 11 Cayenne S
There is rear camber adjustment on our cars, I've adjusted already
Old Jun 12, 2012 | 03:27 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
Shades,
Please tell me were it is and take some pics. Even the dealer tell me their is no rear camber adjustment (just toe).
Old Jun 12, 2012 | 06:51 PM
shades's Avatar
Sure, no problem. I'll put it on the lift tomorrow and snap a few. I wouldn't ask your dealer, ask one of the techs
Old Jun 12, 2012 | 08:46 PM
shades's Avatar
Check
Attached Thumbnails Rear tire replacement question-toronto-20120612-00082.jpg   Rear tire replacement question-toronto-20120612-00074.jpg
Old Jun 12, 2012 | 09:03 PM
shades's Avatar
Shades,
There you go bro....the first pic is the one with the type of adjuster. I believe its a M10 or M12 size...that one is for the toe adjustment. The second pic shows the camber adjustment eccentric bolt. You cannot see the front of the bolt in this pic, its hard enoug to get your M10, let alone my cell phone, but its the same as the toe bolt on the head. Now keep in mind when you make this adjustment its a little tricky to reach, you need a flex head wrench and a M10 or M12 socket head. Very tight!!!
Old Jun 12, 2012 | 09:51 PM
norb's Avatar
2009 C63 AMG
I'm running 265 in the rears.
