hey all, I've done a quick search, but I couldn't find anything..
Apparently it's possible to upgrade the software in the Command unit to make pre MY10 Bluetooth audio capable.
Anyone got any info on this?
I use one of these.. http://store.shopblackberry.com/Prod.../ACC-41596-001 (the one i use is actually the older version, it might be cheaper now that this new one is out)
Connects to the aux in of your car (may be hidden, mine was). It works alongside the MB phone BT with zero issues.. Automatically connects to my phone when i start up the car and all that good stuff. The only thing is it does NOT work if the car is off (it needs to be powered, i use a dual usb port charged in the glovebox) if that matters to you. This part takes some getting used to at first, you learn to not turn the car off all the way if you want the engine off but still want to listen to music.
Don't let the name fool you, I have a blackberry but it worked fine on my old android phone. Anything with the proper BT profiles should work..
Thanks for that..
so, there's a hardware change between the 09 and 10?
just installed a blackberry bluetooth gateway in my 09. works perfectly with my iphone 5 for streaming music. only drawback is you have to unplug the ipod when using (it's either/or).
604 C63
close
- Join DateAug 2011
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2012 E550 Cabrio
Liked:395 Times in 273 Posts
This. The other good thing is that BT audio streaming works on a different protocol than your phone does, so you can connect to the gateway and the car at the same time. That way, when the music is on and the phone rings the music cuts out and the phone call replaces it in your audio system. Originally Posted by drawde
I use one of these.. http://store.shopblackberry.com/Prod.../ACC-41596-001 (the one i use is actually the older version, it might be cheaper now that this new one is out)Connects to the aux in of your car (may be hidden, mine was). It works alongside the MB phone BT with zero issues.. Automatically connects to my phone when i start up the car and all that good stuff. The only thing is it does NOT work if the car is off (it needs to be powered, i use a dual usb port charged in the glovebox) if that matters to you. This part takes some getting used to at first, you learn to not turn the car off all the way if you want the engine off but still want to listen to music.
Pretty much flawless. Between that, the sd cards and 6 dvds of mp3's you could take the entire internet on the road.
EDIT: Except if my stereo is on this works. I have a usb lighter plug in the glove box too. Strange.
BTW I just switched from iPhone to a Nexus 4 (hey I was bored) and Im working on a wireless charging setup discretely installed in the car.
I'll post up when Im done.
I'm using this in my 09. Allows me to skip tracks with the steering wheel controls.
http://www.ebay.com/itm/ML-D100-Blue...-/320963513090
Quote:
Yes. I'm assuming they all did? I haven't seen one that doesn't have it.Originally Posted by 604 C63
you have the ipod kit installed in your car I take it?
ExploreMBWorld Fanatic!
Can you stream pandora as well using this, or is this simply a wireless iPod/iPhone interface solution?
If you have a bluetooth audio capable device with Pandora on it, then yes you can stream it from that via the ipod integration.
Quote:
Sounds good. So it has all the same functionality as when your iPhone/iPod is physically plugged directly into the integration cable?Originally Posted by b16
604 C63
close
- Join DateAug 2011
Quote:
Well,come on over to my house cos all I have is an aux jack in the glovie. I have everything else possible on that car including P30, carbon fibre interior and the back seat comfort package - but not that.Originally Posted by b16
Quote:
It wont display the song title in the console, you can only change tracks. It only displays "bluetooth" lol.Originally Posted by m a x i m u s
Quote:
Ah, gotcha. Thanks for the info!Originally Posted by b16
