two, perhaps stupid, questions.
Second, can you go to manual mode without ggoing to a complete stop?
2) Technically, yes. Recommended? That's a grey area. I toggle between the modes and it's fine.
The second question is just something I've read on here, that you aren't supposed to switch to manual mode without stopping the car, that seems stupid. The car I'm driving had triptronic or whatever and sometimes I'll want to manually shift when I'm bored or I'll want to go back to automatic mode and I never pull over to do that. That just seems silly.
I'm assuming it's fine to go from C to S, though?
With that said, I'm with gthal's thinking. Generally, I'm completely off the throttle when I changes modes or shift into N for revving. I know our cars are smart, but I think that's the "proper" thing to do in case it is bad.
Btw, here's another thought. If we weren't supposed to change from C to S to M on the fly, why can we touch the left paddle and convert C or S into a manual-like mode? Then hold the right paddle to switch back to full auto?
2. I avoid switching while hard accelerations and while shifting. Usually do it while coasting. You would have heard something on this board if this created any issues as gthal said, not everyone follows the instructions.
You'll notice that when you change the trans mode while driving, you can feel a slight but noticable mechanical change of some kind underneath the car. I don't know what that is.
I also agree that if it was bad for the car to change trans modes on the fly, the computers wouldn't allow you to do it, but considering I can feel this slight mechanical movement under the car when I try it, I can at least imagine there is some reason that it's recommended to pull over and change modes when the car is not moving.
