- Mercedes-Benz C-Class: Buying Guide
Important information to help you understand your Mercedes-Benz
Browse all: Specifications and General Maintenance
C63 Head Bolts and Engine Repair
Some say corrosion causes the breakage. The pic I saw looked work hardened. Isn't corrosion too soon on the C 63?
How can we feel assured with the "improved" oem bolt...no failures?
The ARP stud is torqued rather than TTY? Who decides the value? The reading I have done does not show conclusive need for studs. Are the failures from hard WOT work daily, drag racing?
Pure tensile strength of bolt is not significant and the head gasket is moving around during the heat excursions. Are different head gaskets used with the studs? The head , gasket and block are squirming around and doesn't seem that studs are the cure all, though appealing.
Boiler plate says mech engineers carefully calculate bolt, material ,thread,
head gasket compression , scatter plots of compression etc etc before they specify gasket, bolt and values. So MB totally screwed up, partially screwed up, kinda screwed up?? Are we jumping at the studs as racer boys who love the porcupine look during assembly? Has ARP specifically looked at M 156? Some knowledge , but not enough can hurt.
Has any one destructively tested the old oem and new oem in the lathe instrument to see if a weakness does exist just under the heads? Just sayin' as they say.
ARP hasn't touched a M156. Weistec has and did the leg work.
You don't need studs unless you are running the blower. The revised bolts are fine.
We have tons of AMGs here, lots of oil $$$$.
Vancouver has had a couple break.
I had two m156s now, both with over 60,000km with the affected head bolts. Not a problem. One car I bought brand new and drove the **** out of it since it had 30km on it.
If my car was stock, Id leave them alone. But with the blower, Im going for studs. I figure its too risky.
Nevertheless, this thread is very good. All of life can be reduced to statistical events, so from one angle this is just another. I have requested an oil sample kit from Blackstone and am considering periodic checks for coolant in oil, although the turn around cycles (drawing, sending , results) probably could not offset the sudden catastrophic failures some experience. In my case the C 63 is a daily driver (with great spirit) and so leakage might occur slow enough to detect in this way. Regards, motoman
Got a call from dealer saying that the head might be leaking coolant and oil and they will tear it apart and replace all the headbolts with new update ones
)Such a happy camper
I just stopped throwing up and now I am reading that MB is flipping us all off for the failure?
The car is too nice not to fix but the response from MB is ridiculous. Mine needs to be done soon too.
Subscribed.
Any thoughts or suggestions?
Sorry man.
Sorry if that's stuff you already knew. In any case, this is not the first time it's happened, even if it's the first one your service rep. has seen. Keep kicking it up MB's chain of command and they'll pay for most of it...probably? Keep kicking until you find the guy high up enough who can say yes.
First, I remain blown away by the collective knowledge and wisdom of this forum. I have been a lurker for many years as an '02 C32 owner (since new!) and C43 before that. You folks have a depth of experience that is just incredible.
Today I traded in the C32 (121K of wonderful, virtually carefree miles) for an '09 C63. I have read all of the posts on the head bolt issue and here is where I netted out as a result:
- my purchase is contingent on a PPI that will include a compression test and leak down test at the local MB dealer.
- I went with the aftermarket insurance that covers gasket failures regardless of cause
The car is a one-owner with just 20K miles and shows no signs of an issue - at least pre-comp/leak down test.
My questions for you pros - provided nothing comes out in the tests, should I worry about replacing the old bolts with the updated bolts? Should I just enjoy the car without worry unless I see any of the telltale signs?
It will be a daily driver with about 10K/miles per year. It will go out on a track a couple of times a year but won't really have hard duty unless you consider aggressive commuting to be hard duty. I race in a spec BMW class which covers my need for yayas so when I take the car on track it's only for a charity ride or instruction.
Thanks in advance for your thoughts!
- Will
http://marcusfitzhugh.com/CLK/63.html
Anyone in the know, would know they are 5.4L Supercharged, and 6.2L
https://mbworld.org/forums/c63-amg-w...-problems.html
This is not uncommon! In fact MB is well aware of the issue but have chosen not to provide customers with the support that they deserve. This is my third mercedes and I'm hugely disappointed with the fact that the customer service is so poor. The technicians at MB denied even hearing about the issue until I described the symptoms and they were quick to tell me to tow the car in immediately. This will be most likely the last Mercedes I buy. My husband told me to get an infiniti or land Rover but I stayed loyal to MB but they didn't stay loyal to me.
