C63 AMG (W204) 2008 - 2015
Lowering with H&R springs, but not sure on spacers?
Old Nov 26, 2012 | 05:50 PM
MachadoC63's Avatar
C63 AMG coupe
Im lowering my C63 coupe tommorow and I wanted to put on H&R spacers (10mm). When I called H&R they told me they have not made spacers for the coupe yet. I thought it was the same as the sedan? and if im lowered im not sure if its going to rub or not? Has anybody had this set up? I have my stock 18" wheels. Any help would be appreciated
Old Nov 26, 2012 | 06:00 PM
Merc63's Avatar
C63 AMG
I didnt rub with the stock pads and HR springs with 19s.
Old Nov 26, 2012 | 06:04 PM
MachadoC63's Avatar
C63 AMG coupe
Did you have spacers???
Old Nov 26, 2012 | 06:45 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
I have the same issue with H&R. I thought a spacer is a spacer provided our bolt pattern and center bores are the same- which is the same for all MB passenger cars aside from the G. With that said, it made me hesitant to order the spacers that I need because H&R said so- is there something I'm missing or as long as center bore and bolt pattern are the same, there's no issue?
Old Nov 26, 2012 | 09:28 PM
noodleman's Avatar
2014 E63S Wagon
maybe they mean a specific width of the spacer to make the oem wheels flush with the coupe?
Old Nov 26, 2012 | 10:15 PM
MachadoC63's Avatar
C63 AMG coupe
It has me hesitant too, don't know wheteher to buy them or not.
Maybe, but I read other coupes with spacers and was curious to know where did they get theres???
Old Nov 26, 2012 | 10:35 PM
Merc63's Avatar
C63 AMG
NO spacers on the hubs, get the correct offset wheel.
Old Nov 26, 2012 | 10:55 PM
Sometimes you don't have a choice for an aggressively offset wheel, especially if you're staying with stock rims.
Old Nov 27, 2012 | 12:22 AM
MachadoC63's Avatar
C63 AMG coupe
I am staying with my stock wheels, and I obviously can't change the offset so I am trying to make it flush to fenders with the spacers.
Old Nov 27, 2012 | 12:28 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
You will not rub on your H&R springs. From my search, you can run 10mm rear & 12mm front spacers w/o rubbing with your oem wheels.
But I'm not sure if the sedan & coupe uses the same part # spacers from H&R.
Old Nov 27, 2012 | 12:52 AM
MachadoC63's Avatar
C63 AMG coupe
Thanks for the info Roswell! Thats the set up I was looking for. I called H&R but they didn't even give me a part number for the coupe, I might shop around and see what other spacers are available for the coupe.
Old Nov 27, 2012 | 08:46 AM
Mort's Avatar
If you take a wheel off and look at the hub face you see a raised section in the center that the wheel centers on. If it is 8.5mm high and there is no dust cap then the spacers for the sedans will fit the coupe.
Old Nov 27, 2012 | 10:25 AM
noodleman's Avatar
2014 E63S Wagon
Here's a post from my local board about running spacers on the coupe. He ended up running 15mm all around and you can see what it looks like. Stock suspension/wheels.
http://www.puremb.com/forum/showthre...2809#post62809
Old Nov 27, 2012 | 11:37 AM
Mort's Avatar
Here is a link to a Tire Rack Article that tells the number of turns required for a given Lug Bolt size. Our cars have a spec of M14 x 1.5mm. That means the thread diameter is 14mm and has a pitch of 1.5mm per turn. The required number of turns is 7.5. The length the lug bolt should protrude through the wheel and any spacer to be installed is 7.5 x 1.5mm = 11.23mm. Look under Step #5 for the second Note:.
http://www.tirerack.com/installer/package_install.jsp
Maybe post this up it PureMB for those interested. I see it is under discussion.
Old Nov 27, 2012 | 01:19 PM
MachadoC63's Avatar
C63 AMG coupe
Thats perfect the dimension and hub diameter were the same as the sedan, when I checked on H&R so everything fit on just right I will be going with the 10mm rear and 12mm in the front.
Will check that out today just to double check
