C63 AMG (W204) 2008 - 2015
Weistec Stage 3 Supercharged C63 Just Ran 10.50
Old Dec 28, 2012 | 12:50 PM
emericr's Avatar
2021 Porsche TTS
Congrats on the numbers. Very impressive.
I know everyone knows this but I am so happy that MB decided to have the new AMGs with TT.
It takes so much money and dedication to get an NA AMG in the 10s whereas a tune only with downpipes on a CLS63 will get you there (and still under warranty with friendly dealers).
Renntech is supposed to have a CLS running in the 9s early next quarter.
Old Dec 28, 2012 | 01:13 PM
ecampbell's Avatar
2008 BS
Originally Posted by C-63AMG
How long will this last with stock internals? Just curious. And how much on the rear wheels?
These motors are overbuilt from the factory so I would imagine the engine will last as long as...well as long as a piece of string.
Old Dec 28, 2012 | 01:18 PM
Weistec's Avatar
Former Vendor of MBWorld
Weistec
Time slip added to the first post. Quality is not the best but we will update soon. Thanks!
Weistec Engineering
Old Dec 28, 2012 | 01:25 PM
Weistec's Avatar
Weistec
We have made over 700 HP at the wheels with a completely stock engine and we have taken apart several M156/M159 engines that have had hard miles on them, and we are always impressed to see how strong they are built. Our calibrations run these engines very safe and consistent and that is the key to keeping an engine alive.
Our Stage 3 Supercharger System makes about 630 HP at the wheels, and 555 Lb FT Tq at the wheels on 91 octane fuel. Please see the graph below. Thanks.
Weistec Engineering
Old Dec 28, 2012 | 01:36 PM
propain's Avatar
See Sig
What track was this done at? Yas Marina? Any data on DA? Great time of year to run at that track especially at night. If the weather reports are correct for that area its close to 0 DA at 9:30PM.
Old Dec 28, 2012 | 01:54 PM
Weistec's Avatar
Weistec
Yes this was at Yas Marina. We are not sure on the DA. Thanks!
Weistec Engineering
Old Dec 28, 2012 | 02:04 PM
  #32
propain's Avatar
See Sig
Weistec Engineering
Thanks. Congrats. Very respectable time. If he was running an ice tank why didn't he run ice?
What do you figure is the price tag on this application? About 26K not including labor?
Old Dec 28, 2012 | 02:07 PM
  #33
dodger63's Avatar
2013 f250 6.7 diesel
great job weistec this is a perfect example that your products work!
Old Dec 28, 2012 | 02:09 PM
  #34
dodger63's Avatar
funny statement, under warrenty with friendly dealer..... tune your car your warrenty is over. dealer can over look it but then your both commiting fraud..
Old Dec 28, 2012 | 02:14 PM
  #35
Weistec's Avatar
Weistec
We asked the same thing. It is a lot to remember when you are at the track racing and ice definitely helps. Next time out they will make a few adjustments and hopefully see some gains.
Yes that is good estimate of the total cost.
Weistec Engineering
Old Dec 28, 2012 | 02:16 PM
  #36
dodger63's Avatar
Weistec Engineering
cant see the slip well do you happen to know the 1/8 mph
Old Dec 28, 2012 | 02:19 PM
  #37
SLS Qatar's Avatar
2011 SLS AMG, 2009 SL63 AMG, 2008 C63 AMG(SOLD)
Hello Jim,
DA was around +670. Therefore its still a positive DA. Traction was a main problem. The car was so powerful that it wouldn't be stable @ 1st and 2nd gear and would only be stable halfway through third gear.
Old Dec 28, 2012 | 02:20 PM
  #38
Weistec's Avatar
Weistec
Sorry for the poor quality. It looks like a 6.847 @ 104.23 MPH.
Old Dec 28, 2012 | 02:26 PM
  #39
dodger63's Avatar
i figured it out its kmph 164.22 so thats 102.04 in the 1/8 and 132.78 in the 1/4
Old Dec 28, 2012 | 02:30 PM
  #40
amx1397's Avatar
05 crossfire w/SL55 drivetrain installed by Rudy Compart Intake/Needswings best et-10.76 @ 129
great run, seems like you have a lot more in it and can go a lot faster, I'm waiting to see the low 10's,, and maybe you're the one to do it, congratulations jim
Old Dec 28, 2012 | 02:32 PM
  #41
propain's Avatar
See Sig
Originally Posted by SLS Qatar
Hello Jim,
Still quite low. Must have been a warmer night. How did you calc the DA?
Yas right now shows neg DA according to weather reports. Its about 10pm there right now right?
Old Dec 28, 2012 | 02:50 PM
  #42
SLS Qatar's Avatar
I don't know how you calculated, but here is a weather data right now
http://www.timeanddate.com/weather/u...ates/abu-dhabi
Currently according to dragtimes DA is a positive 355
Here is a photo of the screen @ yas showing the conditions yesterday (which was worse, higher temp and higher humidity @69%)
I cant remember the barometric pressure, but when I did the calculation it showed 670 positive DA
We usually get negative DA during the end of January- Early Feburary. We will go out again during that time
Old Dec 28, 2012 | 02:53 PM
  #43
dodger63's Avatar
you also need baremetric pressure
Old Dec 28, 2012 | 02:55 PM
  #44
PetroC63's Avatar
2012 CTS-V
Congrats to Weistec for putting together a solid combination.
Is this the same car that ran 11.0 at the same track in +4000 DA? I think it was with a Stage 1+ kit back then?
Old Dec 28, 2012 | 02:58 PM
  #45
propain's Avatar
See Sig
Looks like a daytime screen shot. Why is the sun out at 9:30 at night?
Either way, its all about the pressure. I was looking at a different site that showed the pressure at 31 rather than 30. That difference can change the DA by about 900.
I am just trying to figure out the corrected time to compare. Either way you are racing in optimal conditions. Why no ice in the ice tank? Any idea?
Old Dec 28, 2012 | 03:07 PM
  #46
propain's Avatar
See Sig
Weistec Engineering
Great job. This is how its done. I am happy to see you guys posting up results and staying away from the drama on other sites. Keep it up.
Old Dec 28, 2012 | 03:51 PM
  #47
M156Beast's Avatar
C63
Your using online conversion , which uses a diffrent factor. If you use the standard 1km-1.6 , the values are actually 133.5 and 104.3. Anyhow and anyway its still superfast. Can't wait to see the video.
Old Dec 28, 2012 | 04:07 PM
  #48
chawkins2001's Avatar
2006 E55 AMG
Sheesh That MPH and 60' suggests there is alot left in that combo.
Slip says 10.576 though....
Old Dec 28, 2012 | 04:22 PM
  #49
M156Beast's Avatar
C63
Old Dec 28, 2012 | 04:23 PM
  #50
dodger63's Avatar
Ok I would figure the online conversion would be much more accurate can you explain why it wouldn't be?
