C63 AMG (W204) 2008 - 2015
What is correct way to take out the hood emblem?
Old Jan 8, 2013 | 04:17 PM
Crazy4Cars's Avatar
W212 E350 AMG E63 Pack.
This is the one I got.
Attached Thumbnails What is correct way to take out the hood emblem?-two-20pins.jpg
Old Jan 8, 2013 | 04:32 PM
Craiger's Avatar
2013 C63 Coupe BS Conversion
I have a 2013 but my hood emblem didn't look like that. 2 clips, just squeeze together and pop it off from the underside. Take 2 seconds, super easy.
Old Jan 8, 2013 | 04:34 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Same
Old Jan 8, 2013 | 06:32 PM
NORTH 44 C63's Avatar
EuroCharged 2012 C63 BS Coupè
Thats a hood emblem from an A170-180 ..NOT a W204
Old Jan 8, 2013 | 06:59 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
You bought the wrong one. The two pin ones are commonly found on ML, GL, R and other vehicles where only the flat badge is available within the model range. The C has both the upright star and flat badges depending on model, therefore the hood is designed differently. The flat badge on the C clips into place and there's a large hollow opening if you remove the badge.
Old Jan 8, 2013 | 07:12 PM
Crazy4Cars's Avatar
The reason that I bought this one is because the ebay seller claims that it has the correct size 57mm and I wanted the same size, maybe I did not read the offering right, anyhow, where can I get one with the right size same as stock and good quality?
tks
Old Jan 8, 2013 | 07:41 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
eBay
Or
http://www.jbspeed.com/servlet/the-M...C63/Categories
Old Jan 8, 2013 | 08:49 PM
ddcha's Avatar
2022 E53 SG
This is the one I just bought. Quality is decent. I'm content with it although not blown away. The center aluminum sticker is a bit thin and I had to press it pretty hard to get it to stick well. http://www.ebay.com/itm/AMG-design-H...00652480651%26
Old Jan 8, 2013 | 09:11 PM
Here's the one I got. I'll snap some photos tomorrow if my car's ready.
Old Jan 8, 2013 | 09:48 PM
Ezec63's Avatar
C63 Coupe
Ahhhh $&!? !! I got the same one as the OP the seller specifically said it was for the w204 guess I got burnt ! How can I make sure I get the right one -__- I have a c63 coupe
Old Jan 8, 2013 | 09:50 PM
You should be able to return it. Next time, ask for a picture of the back or look under your hood first.
Old Jan 8, 2013 | 09:56 PM
Ezec63's Avatar
C63 Coupe
Yea should have looked in hind sight ! Cars been in the shop for a week getting a quaife LSD and secondary cat delete it was an impulse buy o well .. Thanks !
Old Mar 21, 2013 | 11:31 AM
Ezec63's Avatar
C63 Coupe
I ordered another hood emblem from JB Speed and its not a spring loaded clip like the original benz star !! Its just a flat badge with 5 holes in it and they supplied 2 screws and 2 washers. WTF?!?! 2nd time its the wrong one
Old Mar 22, 2013 | 08:16 AM
almoamg's Avatar
RS6, S3
I bought one of these about 4 months ago and it has started to corode and chip already. I'm going to look for alernatives.
Old Mar 22, 2013 | 09:50 AM
ddcha's Avatar
2022 E53 SG
Really? Mine is still fine and there are many other members that haven't had your problem.
Old Mar 24, 2013 | 07:41 PM
almoamg's Avatar
RS6, S3
Yup. Corroded on parts of the edge and it was polished and waxed. Could be 4 months of Scottish weather and road salt!
Posted from Mbworld.org App for Android
