C63 AMG (W204) 2008 - 2015
Bad news after 1 month!! Cel, check coolant, smoke!
Old Mar 1, 2013 | 06:33 PM
myfault's Avatar
c230
So picked up my 09 a month ago with 11k miles from Mercedes greenway in Houston. 700 miles later... I'm sitting in traffic last night and all of the sudden starts shaking at idle, heats up, coolant light comes on, cel comes on, and white smoke out of the back. Pulled over and got towed to dealership.
Here we go
Old Mar 1, 2013 | 06:45 PM
Guilty's Avatar
'16 C63-S
Old Mar 1, 2013 | 07:19 PM
sfury63's Avatar
2012 GTR/2010 C63
I know your pain, been there....GL
Old Mar 1, 2013 | 07:52 PM
myfault's Avatar
c230
do you mind telling me what they did and how everything turned out?
Old Mar 1, 2013 | 08:01 PM
sfury63's Avatar
2012 GTR/2010 C63
here you go https://mbworld.org/forums/c63-amg-w...ant-issue.html
Old Mar 1, 2013 | 08:41 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I would strongly suggest that you read up on all of the coolant/head bolt threads (there aren't that many) before you talk to your service tech. You can compare symptoms and outcomes/costs with the folks who had to go through that exercise. It should also give you negotiating power.
Old Mar 2, 2013 | 01:57 AM
myfault's Avatar
c230
fortunatley I have the factory warranty still on the car + cpo warranty, then an extended warranty after that. I just hope they change the head bolts and get everything right instead of just masking the problem
Old Mar 2, 2013 | 01:59 AM
C-63AMG's Avatar
C63 AMG
Sit there with them while they do it and make sure they use the updated headbolts and not the same ones again.
Old Mar 2, 2013 | 07:54 AM
ddcha's Avatar
2022 E53 SG
I'm amazed there hasn't been a formal recall for this. any updates anyone have on the litigation underway?
Old Mar 2, 2013 | 10:41 AM
That's why you need to research the issue. So you know what a true fix entails.
Old Mar 2, 2013 | 01:51 PM
Merc63's Avatar
C63 AMG
There is a service bulletin for the head bolts now. They will follow it.
If the bolt head popped off completely, it will have be shot around the head like a arcade game.
Old Mar 4, 2013 | 10:35 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
There has been a blank service bulletin out for a while (typical boiler plate language in it, but no details). At least that I have found, can you post, or provide the link to the current SB.
Old Mar 4, 2013 | 11:54 AM
JeffDL's Avatar
C63
this could be fuel injectors based on some of what you are saying. shaking / smoking..
Old Mar 5, 2013 | 01:28 AM
myfault's Avatar
c230
update today. "looks like its going to need a new head gasket."
Old Mar 5, 2013 | 11:09 AM
Tell me they're going to change the bolts too. They have to take them off anyways, so they SHOULD.
Old Mar 5, 2013 | 11:49 AM
jvanbrecht's Avatar
They will, they are not reusing the old bolt style anymore.
Old Mar 5, 2013 | 11:52 AM
I know that they should, I just want to make sure OP knows that it is supposed to be done anyway.
Old Mar 5, 2013 | 01:17 PM
myfault's Avatar
c230
thx guys.. I told my service rep about the bolt issue and please have them use the new bolts. He said don't worry, they know about the issue and everything will be done right
Old Mar 5, 2013 | 01:26 PM
ddcha's Avatar
2022 E53 SG
that's good news. Can you ask your service rep if there is a TSB that replaces the old bolts BEFORE failure? I know warranty covers after failure, but what about a preventative TSB?
Old Mar 5, 2013 | 01:36 PM
Old Mar 5, 2013 | 04:12 PM
myfault's Avatar
c230
I actually asked that when I bought the car from them a month ago. Unfortunately no such luck
Old Mar 5, 2013 | 06:23 PM
From M to AMG's Avatar
Too many to list
Arrow Don't rain on my parade...
good luck with it and I hope they fix it correctly....
Old Mar 8, 2013 | 11:30 PM
myfault's Avatar
c230
Good news!! They put me up in a brand new c class all week, and I got my car back today. Turns out 'some' head bolts broke.
"Installed all new cylinder head gaskets, head bolts (upgraded bolts), lifter hydraulic tappets, all other listed gaskets. Perform 2 engine oil and filter changes. Perform multi point inspection."
Old Mar 8, 2013 | 11:44 PM
johnnyblaze's Avatar
CLS63S
Best case scenario. Great news
Old Mar 9, 2013 | 04:18 PM
fn3423's Avatar
2008 CLS63 AMG 030
Good to hear it worked out for you.
If anything happens to my motor I have a good reference to use and a local one at that.
Thanks for sharing.
